2014 Aprilia RSV-R Magazine Quality Build
Discussion in 'Marketplace' started by Harabec, Sep 8, 2015.
  1. 2014 Aprilia RSV4-R
    Click here to view eBay posting for the bike
    • Race and/or Trackday bike
    • Only 1,671 miles, complete magazine project bike build by EDR Performance
    • Absolutely MINT!, Never raced, never dropped! Used for trackday instruction
    • Over $58,000.00 to build
    • 171 rwhp 78lb/ft and only 399lbs wet!
    Bike bought brand new from Aprilia in the crate, we completely stripped bike and fully built for our client with 0 miles on it. Bike and owner are extremely well know. NEVER RACED this bike has only been used for trackdays and instruction as owner is a new rider/novice instructor.
    Every event this bike is at it is the center of attention! By far one of the prettiest track bike out there that is very well set up by EDR Performance and also extremely fast!
    Includes a full set of OEM Bodywork, Headlights, Mirrors, New Tires (seen in the pictures), and Subframe.
    Performance
    • 100% stock engine
    • Akrapovic EVOII Full Titanium exhaust system
    • MWR Race Air filter
    • Aprilia factory race ecu with conversion to FACTORY set up variable velocity stacks, adjustable traction control, adjustable anti-wheelie, adjustable engine braking and many more features with the updated APRC settings
    • Rapidbike Fuel and Ignition tuner mapped by EDR Performance. Mapped for 92 octane pump gas (can run race fuel as well)
    • Rapidbike quick shifter fully adjustable for both STD and GP shifting
    • Rapidbike MYTuning fully automated wideband auto-tuner for air fuel ratio.
    • OEM Factory Aprilia Variable Velocity stacks added
    • Samco silicone cooling system hoses with Redline Water Wetter
    • Aprilia Corsa Water pipes, bypass thermostat to run much cooler
    • CBE Billet sending unit for cooling system
    • MotionPro adjustable revolver throttle system
    • CBE Billet handlebar control switches “Nintendo buttons”
    • EDR spec 30psi radiator cap
    • Complete dyno tuned mapping by EDR Performance pump 92 fuel
    • Motul 7100 10/60 synthetic oil
    • Denso IU31A Sparkplugs
    • EDR modified slipper clutch
    • Driven billet smog block off plates
    Chassis
    • K-Tech Pro Suspension 20mm DDS Sealed Chamber cartridges with customer EDR spec valving, K-Tech 1.00 spring rate fork springs and Motul Factory line 5wt oil
    • K-Tech 35mm DDS Pro Billet cylinder head rear shock
    • K-Tech by Toby Race spec 55mm Steering damper with EDR custom valving
    • EDR Performance complete optimized chassis set up
    • Tightails lightweight superbike alloy subframe
    • OZ Piegga Forged Alloy light weight wheels with 90* valve stems
    • Pro Bolt titanium and stainless fasteners throughout entire chassis and engine
    • Lightech billet chain adjusters w/lifters
    • GB Racing engine case cover
    • CRG folding billet clutch lever
    • CRG folding billet brake lever
    • Renthal billet Clip on’s
    • Renthal Grips
    • Motoholders alloy upper fairing stay
    • Lightech billet locking fuel cap
    • Drive System 520 Superlight sprockets 16/39(includes spare gearing 15,16,39,40,41)
    • DID ERV3 520 Chain
    • Lightech Billet adjustable rearsets
    • EDR modified shift lever and knuckle -reduced throw,
    • Dunlop US Spec race slicks 120/200 sized 7455 front 7455 rear
    • Full Spectrum P2 Racing lithium battery
    • AMP HD oversized starter and ground cables with quick connect
    • Laptimer mount
    Body
    • Catalyst Racing Composites bodywork, also includes a superbike bolt on seat base with HT moto sbk seat pad
    • Extra color matched lower with cut out for oem kickstand if buyer wants kickstand reinstalled (again seller did mostly instructing so to have the side stand was huge help)
    • DB Superbike oversized intake ducts
    • Zenners Paint Works paint job
    • TankTredz anti slip tank pads
    • Zero Gravity racing CORSA taller clear shield
    • Cox Radiator and oil cooler guards
    • Graphics by DrippinWet
    Braking
    • Brembo oem radial master cylinder
    • Brembo oem M4.34a monobloc calipers
    • BrakeTech stainless superbike full floating, 6mm thick Semi-narrow band 320mm front rotors
    • Vesrah Super RJL brake pads
    • Spiegler abs bypass SS brake line kit
    • Motul RBF660 brake fluid
    *includes custom EDR Spec Pit-Bull rear stand
    Price: $23,900 Or Best Offer
    PM with any questions about the bike and we will provide you with in-depth answers.
  2. Mods, please delete the previous posting for this bike. This one supersedes it.
  3. Bump,
    HUGE price drop to $19,900!
Aprilia Rsv4 2014 fender eliminator install led issues Mechanical & Technical May 8, 2016
2014 KTM Adventure 1190R Motorcycles Oct 31, 2016
2014 BMW R NineT - 1520 Miles Motorcycles Sep 9, 2016
2014 Yamaha FZ09 $6500 firm Motorcycles Aug 23, 2016
2014 Kawasaki Ninja 636 ZX6R ABS Motorcycles Aug 9, 2016
