Brand New 2016 Shoei X-14 (Assail TC-1) Size Medium $500
Discussion in 'Gear, Parts, & Accessories' started by Corkey, May 25, 2016.
  1. Brand New 2016 Shoei X-14 (Assail TC-1) Helmet Size Medium
    This helmet is brand new. Flawless.
    Includes Pinlock EVO lens insert, chin curtain, breath guard, chin spoiler, owner's manual, silicone oil, two spare small stickers and two spare large stickers. Tear-off ready. Helmet has internal speaker cutouts (i.e. SENA, Cardo, Etc.)
    If you have been looking for this particular helmet, buy this one now and Save over $225.
    First $500 takes it. Local cash sale only (Beaverton, OR). Will not ship.
    If interested send me a private message.
    Design Concept
    • Developed utilizing rider input from the world's top racers like Marc Marquez and Bradley Smith
    • Tested in SHOEI's wind tunnel for next-level aerodynamics and ventilation
    • Enhanced high-speed stability while reducing drag and negative forces
    • Ventilation performance features innovative cheek pad cooling system
    • Patent-pending adjustable/rotating liner components for customizable fit and greater field of vision
    Aerodynamics
    • Refined in SHOEI's wind tunnel to yield the most aerodynamic and stable X-Series helmet yet
    • All-new shell shape along with a completely redesigned, patent-pending Rear Stabilizer
    • Standard Rear Flaps can be replaced with optional, narrower flaps to customize aerodynamics
    • Strategically placed ridges along the top shell and chin bar reduce turbulence and drag
    • Maximizes high-speed stability while reducing negative forces to the rider
    Ventilation Performance
    • Boasts six (6) air intakes and six (6) exhaust outlets optimized for maximum airflow
    • All-new cheek pad cooling system
    • Newly positioned side air outlets improve hot air expulsion
    • Wind tunnel-optimized to excel in the tucked racing position, even behind windscreens
    Rear Stabilizer / Rear Flaps
    • Redesigned, patent-pending Rear Stabilizer maximizes high-speed stability while reducing negative forces on the rider
    • Standard Rear Flaps can be replaced with optional, narrower flaps to customize aerodynamics depending on rider preference and track demands
    CWR-F Race Shield
    • Protects from 99% of the sun's damaging UV rays
    • Innovative new ribs on top and bottom edge improve rigidity and eliminate bending
    • Exclusive, patent-pending Vortex Generators reduce air friction
    • All-new double shield locking mechanism prevents unwanted shield openings
    • Provides a flat surface to accommodate racing tear-offs
    • Comes equipped with Pinlock® EVO fog-resistant system
    QR-E Base Plate System
    • Facilitates quick and smooth shield changes
    • SHOEI's patented spring-loaded technology ensures a wind and waterproof seal
    • Strengthened springs for more precise functionality
    • Innovative five-stage rotating dial for shield/base plate fine-tuning
    Multi-Ply Matrix AIM+ Shell
    • Proprietary technology integrates a six-ply matrix
    • Hand-laid interwoven layers of fiberglass with organic fibers and resin
    • SHOEI's strongest, lightest, most elastic shell
    Dual-Layer / Multi-Density EPS Liner
    • Provides enhanced impact absorption by utilizing varying densities of foam
    • Allows cooling air to travel unrestricted through tunnels created in the EPS
    • Precise placement of multi-density EPS material yields a more compact, lightweight design
    3D Max-Dry Custom Interior
    • Fully removable, washable, replaceable & adjustable
    • Exclusive Max-Dry material absorbs and dissipates sweat twice as fast as traditional nylon
    • All-new cheek pad cooling system delivers refreshing air to rider's cheek area
    • Patent-pending rotating liner components increase upper field of vision when in tucked racing position
    • Optional sizes of each section of the center pad for a completely customizable fit
    • Three-dimensionally shaped to match the contours of a rider's head
    Emergency Quick Release System (E.Q.R.S.)
    • Allows emergency medical personnel to easily and safely remove the cheek pads from an injured rider's helmet
    • Helmet can be gently removed from an injured rider's head with minimal load placed on his/her neck
    Chin Curtain
    The chin curtain can be inserted into the lower edge of the chin bar to reduce wind turbulence and noise.
    Breath Guard
    The breath guard can be inserted into the upper edge of the chin bar to help reduce fogging by diverted exhausted breath down out the bottom of the helmet.
    Ear Pads
    The X-FOURTEEN is equipped with removable ear pads.
Brand new OEM 2016 Triumph Daytona 675R bodywork + fender elim - $1200 Gear, Parts, & Accessories Jan 9, 2017
2016 Alpinestars Atem Jacket, Size 40/50 (BRAND NEW!) Gear, Parts, & Accessories Nov 7, 2016
Selling 2013 FZ6R extremely low miles. Never laid down. Practically brand new. Motorcycles Mar 23, 2017
Pit Bull Spooled Rear Stand (BRAND NEW!) - $80 (Salem, OR) Gear, Parts, & Accessories Nov 16, 2016
Suomy SR Sport Alex Rins Replica (Large) - BRAND NEW! Gear, Parts, & Accessories Nov 7, 2016
