Fuel System Help
Discussion in 'Mechanical & Technical' started by danabrenn, Jul 3, 2012.
  1. Good Morning....
    long story short...my son offered to clean the carbs on my 1998 gsx1100f.
    got everything apart...carbs cleaned and had to return home without getting it put back together.
    i need a diagram / picutre / document with the vacuum lines / fuel hose connections for the carbs and the fuel tank so that i can make sure it goes back together the way it belongs.
    does anyone have a suggestion where i might be able to get this information??
    thank you very much for your help.
    best wishes.
  2. my apologies....1989 gsx1100f is the year and model.
    fingers are too fat for this laptop!!!!!!!!!!!!!!
  3. RedKat600
    Everything you ever wanted to know about Katanas including service manuals can be found here:
    http://katriders.com/vb/index.php?
    Be sure to hit the Wiki....lots of good stuff! I'm a member there too....excellent Katana resource.
  4. thanks for the suggestion...
    i will post on katriders.com as well.
    best wishes.
  5. RedKat600
    Are you still in Gresham or in Oxford MA?
SV650 fuel leak Westside Aug 26, 2016
Best place to get a battery Fuel line in PDX? Mechanical & Technical Aug 16, 2016
Rockett Race fuel Track Time Mar 25, 2016
Rockett Race fuel 112 leaded 55gal drum Gear, Parts, & Accessories Mar 25, 2016
37MM Mikuni Fuel enrichers\starter Mechanical & Technical Jul 30, 2015
