Hose shop for making brake lines?
Discussion in 'Westside' started by ericrayl, Oct 12, 2012.
  1. Can anyone recommend a good industrial hose place that will make brake lines in Seattle...The Eastside would be better yet but that seems unlikely.
    Thanks much!
  2. In Portland, Oil filter services can build you any line for anything.
    I have used them for years they do good work.
  3. I used to use a place in Bellingham called Western Fluid Components.
    Closer than Portland anyway.
  4. Texasl
    8,486
    63
    978
    I've used Belfair Hose and Hydraulic, both for personal vehicles and for numerous machines at work. They have always done me right.
  5. Thanks guys. Still hoping to find someone more local. In this case there are some rubber grommets that need to be slid onto the hose segments before crimping....I suppose I could mail the hose and cross my fingers.
  6. shelbyguy
    shelbyguy Picture Whore
    ^^this have dealt with Williams Oil Filter Service for nearly 17 years....hands down, best outfit
    grommet that go around the lines that attach to the surround on the underside of your triple clamp?
    cut one side of the grommet spread apart over line, done.
  7. I went to them for a brake line and they were not able to help me...it was a rubber brake line for a car that attached the reservoir to the piston. Guess there is some kind of special rubber that needs to be used for DOT3 fluid.
  8. R-Steve-R
    R-Steve-R suzukigixxer
    everett has greenshields industrial supply
  9. in kent off west valley highway is a American hose and fitting, i have used them to make a couple items and they did great and where able to press the banjos in for me and then crimp.
    http://www.americanhose.com/inventory/index.php
for those with a garage/shop Central Oct 30, 2007
3 hose gas pumps. Motorcycle Talk Sep 7, 2016
Breather hose question. Mechanical & Technical Sep 30, 2015
For those of you who don't know me... New Users Jun 23, 2015
Eff those guys. Off Topic Oct 29, 2011
