I'll be caging it for awhile...
Discussion in 'Roseburg' started by varment, Aug 21, 2012.
  1. Saw Kirk today on Edenbower after the train cleared the tracks.... (unrelated forethought)
    Last weekend I took off on a coast ride just for shits and giggles and to see how I would handle hours at a time on the Daytona. Stopped for fuel and the bike seemed like the battery was weak.... I should have gone straight home at that point but continued on thinking that was weird... I stopped again at my destination for the night and just out of curiosity I tried to start it again and click click click...
    So long story short bought a set of jumper cables and got a jump the next morning, once for fuel and limped the rest of the way home with no gauges what so ever, it would flicker every once in awhile as it tried to cycle but would then go blank. Right around Eugene the bike started surging like I wasn't making enough juice to fire the spark plugs... at that point it was one mile at a time while I started barking encouragement like a personal trainer at a fat camp... It made it all the way home and as soon as I pulled to a stop in my driveway, it died... I love that bike!!
    I plugged it in and topped it off and pulled the battery out of the bike... After a few tests with my voltmeter I have come to the conclusion that the rectifier is toast... At idle stator puts out 22 volts at all three phases unplugged and 6 volts while plugged. Battery is good and held 13.7 volts for 24 hours out of the bike. Getting the funds Friday to get an FH020AA from here but will be camping so will order it Monday with the plan being to install it the next weekend I'm not camping or at drill.
    I'm also going to take this opportunity to clean up some of the wiring from the previous owner(s) and put a switch on the trickle charger... I'm thinking it is putting a load on the battery when not plugged in and is just a brick unless it is plugged in. I'm also going to wire up an accessory power supply like I had on my Ninja to keep my Ipod and phone charged up. The Daytona also earned herself some cosmetic mods pretty soon...
  2. Shocking, a British made motorized product with electrical issues! crackup:
    Joking aside, glad you were able to limp it home vs. being stranded somewhere. Good luck on getting the gremlins sorted and back on the road!
    Grantizzle likes this.
  3. Lucas, the lord of smoke and darkness.
    It's not real fair to dig on Lucas, they did make one product that didn't totally suck, it was a vacuum cleaner.
    Q: do you know why they drink warm beer is Brittan?
    A: Lucas refrigerators.
    Did you know that up until just recently the DOT required that all motor vehicles equipped with a Lucas electrical system all have one piece of safety equipment?
    Yes, they all had to come with a Bosch flashlight.
  4. [​IMG]
    The current Triumph company doesn't use Lucas electronics!
    Good luck sorting it out and hope you are bock on the road soon!
    Some of the 675 Daytonas have had trouble with their rectifiers stranding there riders.
  5. Not sure if this is related, ex girlfriend had a 2007 675, died on the freeway on a hot day. Rectifier/regulator fried and toasted ecu/battery with it!! The stock ones were not mosfet apparently and extremely prone to overheating. Had to get an ecu off a wrecked bike to avoid $800+ part from dealer.
    Just make sure you replace it with the new version! Dealers all stock the new one, i know i90 in Issaquah had one.
    I would recommend to anyone with a 675 to preemptively replace that part and avoid huge electrical repairs. The only warning sign was a faint sulfur smell 10 minutes before incident as the battery roasted itself :shock:
    Good luck!!
  6. QUOTE=PWALL;2834918]"Not sure if this is related, ex girlfriend had a 2007 675, died on the freeway on a hot day. Rectifier/regulator fried and toasted ecu/battery with it!! The stock ones were not mosfet apparently and extremely prone to overheating. Had to get an ecu off a wrecked bike to avoid $800+ part from dealer.
    Good luck!! -Paul"
    That's what I've been thinking!
    The suspension was crap on the standard model and now this.
    But, I still love it!
    :eek:ccasion:
  7. I'm going with a non Triumph Aftermarket R/R...
  8. Wanna see how you wire your acc. port., direct from batt. with an inline fuse or tap into existing fuse of your choice?
  9. The unit I'm looking at has a 30 amp circuit breaker on 10 gauge wire that goes straight to the battery...
  10. Your lucky you didnt burn up your stator unit. Thats what usely goes when you run on a dead batt. or reg.
  11. Yeah, I'm sure I'd see evidence of my last ride if I took the stator cover off and inspected it...
  12. A Triumph 650 broke down! Blasphemy!
  13. No, not broke down, it still runs.... just doesn't charge right now...
  14. I've been thinking about putting in an accessory power supply on my bike too. Is there a kit you are using or are you piecing it together yourself? Also, how to you plan on tapping into your bike's power? I've seen people get power through the fuse box, but that seems too lazy and sketchy for my taste.
  15. That's pretty much what I did and you can charge the battery through it also.
    :eek:ccasion:
  16. short trips were fine but I just replaced the R/R and am getting 14.2 volts from idle to 5k rpms. I think that did the trick but have a bad feeling the battery is on its way out which wouldn't surprise me...
    I piece things together on my own. Never to the fuse box though. I go straight off the battery with an inline fuse and either use a switch or a relay. On my Ninja 650R I had a male female connector from radio shack wired and mounted in the cockpit infill. the Male connector was wired to the tank bag where I could plug in my phone and ipod. On the same circuit I had a power plug that I plugged my GPS into and Heated grips. 20A fuse and never had any issues...
  17. Hey Mel, where did you buy the connector thats mounted on the bike? Is that a common weather pack style connector?
I'll be around for a bit... Portland Region Nov 6, 2015
I'll Calm Down Now New Users Oct 23, 2015
i'll be in my bunk (custom bike) Motorcycle Talk Oct 8, 2014
I'll just leave this here Track Time Aug 12, 2014
I'll never be a Ninja in these squeaky Sidi boots Motorcycle Talk Aug 2, 2014
