I'm impressed
Discussion in 'Vancouver' started by holypiston, Jul 26, 2012.
  1. I did the longest ride on any of my "aircooled" RDs ever and at a pretty high rate of sustained cruising (for my bike anyway) w/ my GF on WEDS.
    VAncouver to Windy Ridge to Randle...got a late start, so decided to slab 12 to I-5 all the way back to Vancouver at good freeway cruising speed.
    I think I found that tuning that works pretty well for me from 63~85 degrees. Was getting a bit rich up @ the top, but no fouled plugs.
    I had to stop 3 times climbing the stairway to heaven...some hikers said, keep going, it's worth it!
    Anyway, i think the key is good head work, stock compression and a tight squish clearance and a good electronic! ignition. PUmp gas, revs no higher than 8.5k for a streeter, remember that for reliability...you have been warned!!!!!!! cheap JASO-FC (works for me) mastercraft oreilly two stroke oil. found 24:1 wasn't burning all the oil....went back to 32:1 and a 220 main jet and that's about as good as it gets for the temp/altitude variances i encountered....got really nice around 7 pm heading back on long highway 12 to I-5 and back home and the rollons were fantastic. Heads setup for .042" squish X 10.5mm X 14 degree angle...have a TZ style base gasket (ala Lyn Garland...old two stroke racer, sells varying thicknesses) that lowers that number to around .034" squish...can't do this w/o the heads perfectly centered..so dowel pins locate the heads perfectly. 25.7 c.c. volume in the heads. with stock gasket it's .042"...wanted a little bit more in the midrange.
    anyway...woo fricken hoo. good reliable power that doesn't fade (not much)...good head mods. helps to not ride like a jackass all the time either...keep that throttle hand in check or have a chase vehicle w/ leaded 115+ race gas and LOTS of premix...oh hell, then you have to re-jet again...!!!
    Thanks to RB Designs...he also ported my daytona to stock 400 specs so the head work would work... Also....NO head gasket....strictly o-ring head...and no the o-ring won't melt. I've already holed a couple pistons and the o-ring was fine and never leaked...KILLER seal for the aircooled RD. Stock compression and tight squish...i think i like it.
    I really thought i would seize coming all the way home on I-5 from Morton hi-speed cruising...we did stop once for gas, but that was it.
    impressive. thank god a least Ron knows what he's doing...got damn, i say got damn...even my Goil friend was impressed. She said this was a rippin'...and it really rips w/the 210 main and 80+, but it's not always 80 degrees here, so tune realistically for the micro-climate stuff...
    a few rollons here and there from 70-90 helped break up the monotony and then backing down from 6k cruising and hitting a higher gear and then 5.5 k cruising.
    So in conclusion, for my ride the 210 main is great for 80+....the 220 works fantastic in the 60s, but the 220 is the better all around choice for a monster ride like this<---and a ride like this IS a monster for an aircooled two stroke.
    dam....it didn't blow up....i must be doing something right, finally.
OK.. I'm impressed, who needs a "track bike"? Motorcycle Talk Aug 10, 2008
Motorcycle Legend Lawson Impressed By New IMS Road Course Motorcycle Talk Feb 5, 2008
Real impressed by revhard Yakima Aug 13, 2007
Nope, not impressed. Westside Apr 22, 2007
