Just what is acceleration...
Discussion in 'Mechanical & Technical' started by Dr. E, Feb 11, 2010.
  1. Dr. E
    5,632
    23
    868
    DEFINITION OF ACCELERATION
    One top fuel dragster 500 cubic inch Hemi engine makes more horsepower than the first 4 rows of stock cars at the Daytona 500.
    It takes just 15/100ths of a second for all 6,000+ horsepower of an NHRA Top Fuel dragster engine to reach the rear wheels.
    Under full throttle, a dragster engine consumes 1-1/2 gallons of nitro methane per second; a fully loaded 747 consumes jet fuel at the same rate with 25% less energy being produced.
    A stock Dodge Hemi V8 engine cannot produce enough power to drive the dragster's supercharger.
    With 3,000 CFM of air being rammed in by the supercharger on overdrive, the fuel mixture is compressed into a near-solid form before ignition.
    Cylinders run on the verge of hydraulic lock at full throttle.
    At the stoichiometric (stoichiometry: methodology and technology by which quantities of reactants and products in chemical reactions are determined) 1.7:1 air/fuel mixture of nitro methane, the flame front temperature measures 7,050 deg F.
    Nitro methane burns yellow... The spectacular white flame seen above the stacks at night is raw burning hydrogen, dissociated from atmospheric water vapor by the searing exhaust gases.
    Dual magnetos supply 44 amps to each spark plug. This is the output of an arc welder in each cylinder.
    Spark plug electrodes are totally consumed during a pass. After halfway, the engine is dieseling from compression, plus the glow of exhaust valves at 1,400 deg F. The engine can only be shut down by cutting the fuel flow.
    If spark momentarily fails early in the run, unburned nitro builds up in the affected cylinders and then explodes with sufficient force to blow cylinder heads off the block in pieces or split the block in half.
    In order to exceed 300 mph in 4. 5 seconds, dragsters must accelerate an average of over 4G's. In order to reach 200 mph (well before half-track), the launch acceleration approaches 8G's.
    Dragsters reach over 300 miles per hour before you have completed reading this sentence.
    Top fuel engines turn approximately 540 revolutions from light to light! Including the burnout, the engine must only survive 900 revolutions under load.
    The redline is actually quite high at 9,500 rpm.
    Assuming all the equipment is paid off, the crew worked for free, and for once NOTHING BLOWS UP, each run costs an estimate $1,000.00 per second.
    The current top fuel dragster elapsed time record is 4.428 seconds for the quarter mile (11/12/06, Tony Schumacher, at Pomona , CA ). The top speed record is 336.15 mph as measured over the last 66' of the run (05/25/05 Tony Schumacher, at Hebron , OH ).
    Putting all of this into perspective:
    You are driving the average $140,000 Lingenfelter 'twin-turbo' powered Corvette Z06. Over a mile up the road, a top fuel dragster is staged and ready to launch down a quarter mile strip as you pass. You have the advantage of a flying start. You run the 'Vette hard up through the gears and blast across the starting line and pass the dragster at an honest 200 mph. The 'tree' goes green for both of you at that moment.
    The dragster launches and starts after you. You keep your foot down hard, but you hear an incredibly brutal whine that sears your eardrums and within 3 seconds, the dragster catches and passes you. He beats you to the finish line, a quarter mile away from where you just passed him.
    Think about it, from a standing start, the dragster had spotted you 200 mph and not only caught, but nearly blasted you off the road when he passed you within a mere 1,320 foot long race course.
    ...... and that my friend, is ACCELERATION!
  2. vagrant
    vagrant »-(¯`·.·´¯)-> PNW
  3. It seems even mods aren't immune from reposting :ninja:
    And technically speaking acceleration is defined as the change in velocity over time (This is the Mechanical/Technical section, we might as well be accurate in our descriptions).
    -Jake
  4. (a pair of fuel cars staged and ready to leave, accounts for pretty much the whole field of left turners)
    :thefinge: :mrgreen:
  5. Thank you Bill Nye The Science Guy! Wow that is alot of info.
  6. Yeah, but I'm still trying to get my brain wrapped around that "square second" concept.
Is there an acceleration ban in WA? Portland Region Apr 11, 2013
08 Kawasaki Ninja 250 Randomly lost acceleration! Motorcycle Talk Dec 24, 2012
one more question... "acceleration".. Law Enforcement Jul 22, 2012
Acceleration 1992 Seca 2 Mechanical & Technical Feb 8, 2012
Seca II acceleration question Motorcycle Talk Feb 8, 2012
