Leaking oil now too?
Discussion in 'Mechanical & Technical' started by jonnyb347, Aug 28, 2012.
  1. I've still yet to solve why my bike overheats, i've flushed the system with vinegar multiple times, check thermostat, put on new radiator cap, bled the lines, water pump fins looks good and water moves through radiator when bike is moving.
    still have a code 34(exhaust servo, which is taken off now). Servo buddy is on the way.
    i see this beneath my bike now, looks like oil coming from a wire hole above the waterpump, and on the oil pan you can see lots of buildup, and there was a fresh drop of oil on the bolt.
    I am too broke for a mechanic, and this is my only transportation. Bike has 30k miles. Why would it be leaking oil? running lean/rich? that attribute the code 34 and overheating too?
  2. RedKat600
    Two questions for you.
    First, have you removed or replaced the thermostat? Checking it may be inconclusive.
    Second, have you verified cooling fan operation?
    Third, got some time this week/weekend I could help you with it?
  3. I have removed the thermostat to test it, i broke the housing and had to buy a new one. and didn't have a gasket so I used silicone gasket stuff around the old gasket.
    fan works right at 210.
    all i have is free time, no job.
  4. RedKat600
    So there is no thermostat in there at all now? Or is the old one in there?
    For clarification, the fan kicks on and the temp still goes up? To what temp?
  5. Jims08Z06
    Jims08Z06 Bat Crazed
    First I would take RedKat up on his offer. Second get a new thermostat I'm not going to explain. Next check the condition of your radiator, when was the last time you flushed out the bugs and road debris. If your riding year round, one picks up tons of junk which would decrease the cooling ability. Modern engines run hotter, my fans don't come on until 217 degrees. But when moving even on a 90 degree day the motor runs at about 190. One can also add "Water Wetter" I use Royal Purple, which will reduce temps a few degrees. It's difficult to help much when one cannot have a hands on inspection...AJ
  6. RedKat600
    I filled my system with Engine Ice after a complete flush. Made a WORLD of difference but it sounds like this dood has bigger issues.
  7. RedKat600
    On second thought, it may be easier if I come to you. Do you have some place to work and a decent assortment of tools??
    I live off exit 6 on I5...might be a stretch to get here. Let me know....got a couple evenings free this week.
  8. Jims08Z06
    Agreed, check his radiator, bet it's filled with dirt/bugs/shit and some bent fins. I always spray out the bugs after each ride, and like yourself run a water wetter. A cox radiator guard is a must as those dinker fenders don't do much to protect the front of my bike. And I would never ever reuse a thermostat never. Mighty nice to offer a hand...AJ
  9. RedKat600
    Thanks dood. I had someone help me out A LOT a long time ago. I figured it's good to pass it around. Never know when I'll need it again. :mrgreen:
  10. Jims08Z06
    I don't know how much time you can spend on his machine. But I would want to see the plugs. A compression check, check the condition of the fluids, water/oil no mix I hope. Maybe take a peek at his air cleaner. Like yourself some very patient folks helped me get started many moons ago. It's very thoughtful to pay it forward...AJ
  11. RedKat600
    Ya, I have a checklist already in my head. Just need to get some items marked off is all when I see it in person.
  12. RedKat600 to the rescue again. Way to go! I hope you can help them and make friends on the way. That would be really cool. I used to try and help on the internet forums but got slammed for it. It's nice to see someone can do it successfully.
  13. whoa you guys are awesome.
    first off the thermostat is still in there, i put the old one back in. I'll order a new one tomorrow. I checked the radiator for debris and didn't see anything major, there are some bent fins but it looks like normal wear n tear. I can try the water wetter and spraying it out for bugs just incase, i havent done that yet.
    redkat600, No garage, that's my biggest problem or I would have it all ripped apart. I live in apartments and I'm not even allowed to work in my parking spot, and i don't like to leave anything on the street because there are lots of thefts here.
    I can possibly take it to my moms house in vancouver, wa. I think she has a garage i'll ask.
    I have some basic tools, but I can buy some more if needed. I really just have a ratchet and a couple sockets and allen wrenches.
    yes the fan kicks on always around 210 when stopped, and the temp will sometimes hover around 210. but if it's warm outside, anything over 80, the bike will get closer to 220+ usually i start riding or turn it off at that point. It's when i'm riding it seems to get really hot, also the seat gets really hot? I've never had my but get HOT from any other bike i've had. Before I did the flush though the temp would easily climb to 240+ skipping digits, but the weather was a little hotter then as well.
    I definitley have some problems with the leak, and the bike seems like it wants to die at times. The RPMs dropped today to about 500 when I hit a stop light after I left my house, bike was at about 120 degree F.
    Just feels off. I'll keep checking this thread if you have any other questions let me know. Hopefully I answered everything so far.
  14. Have you burped the system?
  15. I'm betting on a clogged Rad + old Thermostat.
    When I picked up my CBR900rr parts bike. The Rad looked like it had 10K on it, like new.
    I spent and hour pulling tinny feathers out of it. Couldn't see em right off, but when I put a light on the back side I could see tons of crap in there.
    Hot soapy water, compressed air, tweezers and a few minutes of close inspection will do wonders.
    Had issues with a turbo 460 Ford. The thermostat would stick, then pop open. I got a trick after market one for like $12 and it was great. Took like three seconds to fully open.
    My old FZR OEM Thermo was $25-$30!! I put in a Ford. It was the same size and a 180*, $5.
    Also when I got my CBR, the in-Rad fan switch was broken. OEM was $67. I did some research and found them for $35. I thought that was too much. So looking on the Fireblades forum. Some people were using auto switches. They kick in at 200** or something but turned off at like 180*. About $20. Just had to find one with the same threads. Most are two wire and the Honda was one wire, easy mod. The parts bike had a new one so I never had to go there.
    Just my worthless 2C.
    You may find there are some options to stock parts.
    Takes a bit of farting around to find what works. Helps if you have a buddy at an auto parts store that can check and compare lots of parts before you buy.
    Anyway. Really like threads like this. I stand a good chance of learning something useful:thefinge:
    :popcorn:
    P.S. Tried to Rep the Kat, but need to spread it around first.
    I think RedKat had got a permanent foot print on the plate he's stepping up too.
    :headbang::salute::notworth:
  16. RedKat600
    Can you make it to LaCenter, WA? Google it and let me know. That's where I live.
  17. ya it's only 50 minutes from me, should I order the new thermo first?
    let me know if you wanna do it on the weekend or a weekday or what works best for you. and what I need to bring(more antifreeze? water wetter?)
  18. RedKat600
    Tonight? Just bring yourself and the bike for now. Testing needs to be done. I'll be home around 5:30 PM if that works for you. PM Incoming with address.
  19. RedKat600
    Sorry our schedules didn't work out. I'm gonna bump this in the hopes that someone else can take a look at it and help you out who lives a little closer.
    I'll check back and see if it's fixed or not.
'05 250 ninja. Leaking water from muffler? Mechanical & Technical Feb 20, 2015
Leaking air from valve (car) Westside May 6, 2014
fork seal leaking.. to ride or not to ride? Mechanical & Technical Jan 21, 2014
Fork seal leaking? Mechanical & Technical Jul 2, 2013
Leaking oil from valve cover gasket Yakima Jun 27, 2013
