more power out of my 636?
Discussion in 'Mechanical & Technical' started by bwboley, Mar 22, 2012.
  1. 05 636 i have k&n micron slip on and a power comander, jumper mod. and dyno tuned to 113 rhp [from nels] just wondering what else can i do to get a few hp out of it then maybe have it retuned?
    I was thinking maybe adding this?
    http://www.pineboxonline.com/raceheader.html
    also herd you can do somthing to the intake?
    Thanks brad
  2. Full exhaust, ECUunleashed (if/when it's available for your bike). Intake mods don't really gain any power for modern sportbikes, but doesn't hurt to get a performance filter - short of any gains, it's nice to have a filter you can recharge and reuse. Beyond that you're probably hitting a ceiling unless you start doing internals... but for that sort of expense you might as well just get a litre bike.
  3. RedKat600
    That dyno graph he posted? The majority of those gains are probably the difference in a professional map vs one he just downloaded off the net. That 12.5 HP gain is a bit much for a 600 with just a header swap and a tune. Take that with a grain of salt.
    That said, that's about the only way to get another 2-3 HP easily without doing internals. And don't mod your airbox. It's tuned for your intake and your FI system. Just ask Nels about hacked up airboxes.....he'll tell you.
  4. Does your slip-on delete the catalytic converter? A full system might help a little (1-2 HP), velocity stacks might help some, K&N air filter. 113 is pretty good for a 600, granted yours is a 636, so that pushes it to the high end. Without getting into timing/ignition advance and running race gas, there's not a whole lot you can do without some serious internal stuff.
  5. PeteN95
    Install ZX10 motor! ;)
  6. Lol I thought about buying a new 2010 zx10th at pro cal but decided to use the money there totaling the bike for on a 2 piece leather suit for track days
    The slip on does not delete the cat
  7. Stickers. Each one is a couple HP at least. Put 5-6 on and you'll be golden
  8. That's actually some really good power out of a 600, I think you should really be happy. Is there any particular reason why you're still looking for more, or are you just doing it for the hell of it? That's enough for almost any local track (unless you're drag racing) and more than enough for the street.
  9. +1 those are really nice numbers... and pretty smooth too!
  10. I'm just seeing if there's more I can squeeze out of it might cut the car and Idk lol
  11. Gotcha. Nothing wrong with that, we all tend to want more power than we can ever use. I think the main issue is that you can't really get much more out of it before tearing apart the engine and spending some $$$.
  12. The headers will help some. That's a good price for a "ghetto" full system. I'd start there and with the air filters
  13. RedKat600
    He's already got a K&N.
  14. All acceptable mods.... 8)
  15. Call edrperformance and do a supersport build... valves,mill head, port/pollish thinner head gasket...135 hp? got $3000ish laying around...and get the full exhaust/header. Im not sure if your cats are in the header or if its actually the boom box
  16. I bet you want to kick your own ass once you realized you should have bought the Yamaha, huh?
  17. Uurrrrh wouldn't your tuner (nels) be a good person to ask?.......
  18. james1300
    Have you changed your gearing? Can you pull to redline in 6th?
    No? Then your leaving H.P. on the table.
    Or, in the gear box.
    Use what ya Mama gave ya!
MorePowerRacing Coupon Code? Motorcycle Talk Aug 12, 2011
Triumph’s Rocket III Roadster gets more power and torque Motorcycle Talk Oct 2, 2009
Has Anyone Ordered Anything From More Power Racing? Westside Jan 1, 2009
MorePoweRacing.com Motorcycle Talk Jun 30, 2008
More Power! Motorcycle Talk May 14, 2008
