new member with question
Discussion in 'Mechanical & Technical' started by cjberquist, Nov 25, 2012.
  1. Hey guys im new to the forum.i own a 02 gsxr 600 and have ran into a very annoying sound i cant figure out or find exact issues on other threads. So when im doing about 60-65 the bike makes a whirring noise but not constant its a whir whir whir whir.whir and so forth until i let off throttle or speed up . its annoying more than anything because my commute.consists of me hitting that speed for a half hour. Any input would help thanks guys
  2. Oh ya what he said below makes more sense
  3. Buddy with a newer gsxr 600 had some weird sound problems at certain rpm's and it was caused by his air intakes tubes not on correctly. it was making some weird noise at certain rpm/amount of air coming in.
  4. Awesome I'll def have to check on that , I'm hoping it's something as simple as that
  5. Dr. E
    5,632
    23
    868
    Welcome to the forum...always good to have new riders.
  6. RedKat600
    I would also check your chain and sprockets. Make sure its not too tight or loose. Make sure its lubed too!! Dry chains can make that sound.
  7. Check your blinker fluid reservoir.
  8. KevinD
    It might be too full, and the pressure is causing it to buzz at speed...
  9. I was thinking possibly the pressure bearings inside might be worn
  10. Fairings resonating.
  11. I have a 2000 GSXR 750 that made a noise like that, it turned out to be the speed sensor star on the front sprocket, was loose and rubbing on the sprocket cover
    Posted using Outdoor Hub Campfire
  12. What was it, OP?
  13. The "original poster of a thread" OP
    Like cjberquist is the OP here
  14. RedKat600
    I do not understand this post.
  15. Me neither!
howdy, new member with questions Portland Region Jan 21, 2011
New member, picking up new ride on Tues. - few questions Motorcycle Talk Jan 17, 2009
Willow????? kris jefferson county. remember me? Kitsap Feb 9, 2017
New Member SLU/Seattle New Users Jan 24, 2017
Returning Member New Users Dec 4, 2016
