October SCREAMIN Deals - $39 Oil Change, $199 Minor Service, $399 Major Service
Discussion in 'Motorcycle Talk' started by KFG Racing, Oct 5, 2012.
  1. Don't let fall scare you away from maintenance!
    Three levels of SCREAMIN deals:
    $39 Oil Change
    $199 Minor Service
    $399 Major Service
    *(Parts & tax not included)
    Call us to schedule your appointment today 253-397-4474 or info@kfgracing.com
  2. Dragon Rider
    Dragon Rider Post Whore (In Training)
    OK thanks for being a site sponsor
    but before I can evaluate the offer,
    what is included in each of the three levels of service?
    (I can do my own oil change, w filter for $8 in parts and 10 minutes of my time $30,)
  3. ninjaofdoom
    ninjaofdoom <a href="http://pnwriders.com/motorcycle-talk/8554
    Grats!
  4. Minor Service: 2.0 - 3.0 (Depending on Bike)
    Engine & Carburetors:
    &#8226; An oil change
    &#8226; New oil filter
    &#8226; New air filter (or cleaned)
    &#8226; New NGK spark plugs
    &#8226; Replace coolant
    Chassis & Brakes:
    &#8226; Battery checked - terminals; clean and tight, electrolyte level, held down securely.
    Vent Tube - not kinked, routed properly, not plugged.
    &#8226; Brake calipers removed & cleaned
    &#8226; Brake pistons degreased
    &#8226; Chain adjustment, cleaned and lubrication
    &#8226; Frame - cracks at gussets, accessory mounts, look for paint lifting
    &#8226; General lubrication and inspection
    &#8226; Hydraulic fluid system flushed
    &#8226; Levers & pivots cleaned and lubricated
    &#8226; Lights checked - headlight, taillight, brake light & turn signals
    &#8226; Steering - Head Bearings, no decent or tight spots through full travel, raise front wheel, check for play by pulling/pushing forks.
    &#8226; Suspension - Front Forks, smooth travel, equal air pressure/damping, anti-dive settings. Rear Shock - smooth travel, equal pre-load/air pressure/damping settings, linkage moves freely and is lubricated
    &#8226; Swingarm Bushings/Bearings, raise rear wheel, check for play by pushing/pulling swingarm
    &#8226; Throttle & clutch adjustment
    &#8226; Tire pressures checked and adjusted, check tread depth, wear, weathering, evenly seated, bulges, embedded objects
    Major Service: 4.0 - 8.0 (Depending on Bike)
    Everything listed above +
    &#8226; A thorough check of your valve clearances (adjusted if needed)
  5. Are_Six
    Are_Six Moderator Staff Member
    Where do you get your free oil? Recycling isn't always a good thing...crackup:
  6. Any specials on Ohlins TTX Shock Service? :)
  7. Great deal! I'll be calling soon for a major on my FZ1.
  8. Just mention you're a PNW member, 10% off!
  9. I just might do this, gotta get a full check-up done on a bike I just bought.
  10. Does this include a full brake bleed / fluid flush (the minor service?)
  11. Mic
    Mic Retired
    I'm going to go with, yes.
  12. Yes sir!
  13. Bump..... special still going on for two weeks.
  14. If anyone is trailering a bike from north (I'm in bellevue) to KFG for service, if you have space in your trailer or truck and can take my bike there for a servicing, I would be very grateful!
  15. U work on Buells? I need my valves adjusted ... shit. I need my chain serviced.... shit... I need... to figure out what the fucking high pitch whining coming from my bike is.. really tho
  16. Does this apply to Harley's?
  17. Some, give us a call or email to let us know what Buell you have.
  18. Sorry, we don't typically work on Harleys.
  19. Auh Dang...
  20. Screamin deal I say.. wish I were closer I need a major done one my duc...think their picky on it being done by a ...duc cert tech tho :(...399 instead of 1200 sounds mighty fine to me
Wednesday Westside Standing Ride (June-October) Portland Region May 26, 2016
Father's Day in October Motorcycle Talk Oct 30, 2015
Childrens Toy Run (TriCities, October 25th, 2015 Central Oct 23, 2015
October meetup. Medford Region Oct 14, 2014
The Ridge, October 11,12 Central Sep 24, 2014
