These bolts look pretty important, any idea where they go?
Discussion in 'Mechanical & Technical' started by jonnyb347, Aug 17, 2012.
  1. 2005 636, had everything ripped apart, replaced thermostat housing. My brain is super foggy right now, what the heck are these bolts for. They look important since they are so big.
  2. Are they from the engine mounts? Did you put frame sliders on?
  3. I have frame sliders already on, but they are already screwed in. Or are these the bolts that were in place of the sliders?
  4. Holding down the bottom half of the air box?
  5. With those collars they look like they go through a rubber gromet or plastic piece to me and they're fairly long. Try airbox as stated before or battery box depending on the bike.
    EDIT: Is that grease or locktite on the end of the threads? They look like they could be through bolts if that is dirt/grease.
  6. never touched the airbox, only took off gas tank/thermostat and obviously fairings.
    annnd the bike still f'ing overheats. thermostat tested fine, fluids flushed. ordering a servo elim and hopefully that helps.
  7. Bad water pump impeller. They could be out of the tabs on the back of the tank. They are usually rubber mounted.
  8. RedKat600
    Erm, those look like gas tank hold down bolts to me. The ones up front.
  9. ^^^ Oh yeah, Kawi and most newer yamaha's have the pivot near the battery and the front tank holders. Good call redkat.
  10. james1300
    Tak'em to a Kawi Dealer's shop and ask?
  11. Well its back together.... Obviously you didn't need them lol. Just say F it take the weight savings lol.
  12. The gas tank has 4 bolts, 1 up near handle bars, and two below the seat that are black. Then the pivot bolt.
    I'm saying F it, obviously I didn't need the bolts. Rode around today and nothing fell off.
  13. Haha. I like your style bro. I've had this happen to me almost everytime I've taken something apart. Never had any bad come of it. lol
  14. If you don't have bolts left over when you're done, you didn't do it right.
Going Nuts For Bolts Central Jul 5, 2015
Looking for a pro at removing broken/stripped bolts Mechanical & Technical Apr 15, 2014
Siezed bolts on speedo Motorcycle Talk May 28, 2013
Need new bolts for springer forks, what to look for? Motorcycle Talk Mar 30, 2013
Local Places to Find Banjo Bolts? Motorcycle Talk Dec 18, 2011
