VFR 800 Valve Adjustment - 8 HOURS!?!?
Discussion in 'Motorcycle Talk' started by FuNCHun, May 22, 2010.
  1. Called Lake City Powersports to get an estimate on getting a valve adjustment and they said... 2.5 hours to check them, another 5 hours or so to adjust them. Does it really take this long? 2006 GSXR 600 only took a few hours. Am I missing something?
  2. It's a honda, gotta make sure there is job security
  3. That does seem pretty steep to me. I'm an equipment mech, not a Professional Motorcycle Technician, but I can check the valves on the CBR and have it put back together, while drinking beer, smokin and bs'in, in 1 hour.
    Don't really understand unless there are some funky tight spots, or neccessity to drop the motor to shim/adust the valves, but that is a possibility. But that's the price you have to pay if your mechanical abilities are exceeded by the technology of the bike you ride. Ask around and see which one of your buddies is familiar with this procedure, and then learn how to do it yourself. You may even be surprised at how easy it really is.:mfclap:
  4. Go to VFRD there is some useful info about valves there
  5. I could see it taking twice as long with a V4.
  6. Everything is dependent on if it is a V-Tec engine. Then yes that will be what you can expect to be quoted. Those also have "shims" that are actually the buckets. They suck.
  7. Rippn
    Rippn Human Race Qualifier<br>FREE and clean
    v-tec valve adj.... the dirty little secret.
    FREE and clean, Ripp'n
  8. with a vtec you have to pull the and reinstall the cams twice....6 to 8 hrs is about right...
  9. cascaderider
    cascaderider Moderator Staff Member
    :mfclap:
  10. if you ain't doin' it yourself...
  11. Also those vtec motors were cam chains not gears so that is also going to add to the time. 8 hours sounds about right.
  12. that bike is a royal pain the the ass to do. the shim buckets that cost like $25 a piece are a joy. what asshole engineer decided that it would be a good idea to stop using the 7.48mm shims and go to a bucket shim.
    8 hours is it.
  13. Yet another reason to stay away from that friggen Vtec.
  14. Sounds like adjusring the valves on a ducati monster, every 6k miles it costs around $600-800 for the 6k service which is basically the valve adjustment. Big fin ripoff
  15. A v-tech v-four? Yeah, probably a bitch to do a valve adjustment. Stick to I-4s for easy/cheap maintenance.
    What do you do for a living? I would love to walk into your work and say you are ripping people off. I'm sure you tell the tech that "rip-off" bit when you bring your ride in for service.
    If you aren't doing it yourself, then don't bitch about the price. Welcome to motorcycle ownership, it's expensive.
  16. I put about 24K on an '02 Vtec. Yes the valve adjust is expensive and time consuming, otherwise an enjoyable bike that can surprise supersports while being comfortable.
    My philosophy was to never adjust the valves unless it started running funny - it never did. The worst that could happen is a burnt exhaust valve which wouldn't cost much more than the friggin' adjustment. Just ride it!
  17. I'm pretty sure you could do a lot worse than a burnt exhaust valve. I've seen valves sucker punch a piston from too much lift.
  18. How would a valve gain lift by not adjusting the valves? If anything the clearances get tighter from seat wear. Thus the valves sit higher in the head further away from the pistons.
    If you are getting loose valves from cam or bucket wear still then you are not gaining any lift.
    Burned valves are yucky!
    Tell me a valve job is cheaper than a valve adjustment!
    But of course this was not due to tight valve clearances. Has more to do with 200k+ miles and worn the hell out valve guides.
Fork Seals/Valve Adjustment - Any local mechanics? 06 CBR1000RR Kitsap May 9, 2014
Valve Adjustment before tune? Tune before Valve Adjustment? Motorcycle Talk Apr 3, 2014
valve clearance adjustment Mechanical & Technical Aug 23, 2013
Valve adjustment FZ1 ? Mechanical & Technical Jun 3, 2013
Valve adjustment/major tune up Westside Jun 2, 2013
