Wiring in walls?
Discussion in 'Vancouver' started by Devil1, Jun 7, 2012.
  1. Devil1
    Devil1 Blingaphobe
    Is anyone here profiecant with running wires through walls? I need help hanging all my surround speakers and 2 of the walls are exterior so I know that would pose a challenge. I've had one estimate and he said it would take 2 hours and $500. Uhhh I'm in the wrong biz for sure.
  2. Hmm... Are you in a hurry? I wouldn't mind trading some work for a place to sleep the night before a PIR track day. July 1st mebby? Night before Motocorsa at PIR...
  3. Devil1
    Devil1 Blingaphobe
    Do you do this often or by trade? Or have you done it before?
    Let me chat with the wife. We do have a spare bed.
    Need not apply if a creepfest :)
  4. Nice... No creeping. I do it as a hobby; my house has almost a mile of different kinds of cable (25pair CAT3, CAT5, alarm, speaker, etc...) and the house sits on a slab with a daylight basement; no under the house access.
    I am not a professional but I certainly know my way around construction and have really long drill bits (amongst other fun tools). If you have access to either the top or bottom of the wall, the job shouldn't be too difficult.
  5. 1) Drill whole at top of wall
    2) remove base board
    3) Cut 3" long by 1" tall hole where base board was covering
    4) run this through the whole drilled at the top of the wall, down to the 3" by 1" rectangle
    5) tape speaker wire to the fish tape, and pull backup
    Just did this on sunday. Took me maybe 30-45 minutes for the whole project
  6. also - this was all done on an outside sharing wall
  7. Write the check and go for a ride.....
  8. Devil1
    Devil1 Blingaphobe
    Yeah I've got a decent crawlspace.
    Thanks for the info. :mrgreen:
  9. Obviously one of my best friends! :roll:
  10. I would use one of these Fiberglass Fish Tape, much stiffer and way easier to fish through walls. If you want to go a long distance through open spaces like walls and under floors, the steel tape will get very flimsy. It's really only good for fishing conduit or straight down. The fiberglass one will work better for open horizontal runs.
    I'm currently an Apprentice electrician with IBEW 48. I'm by no means an expert yet but i've done my fair share of wiring and 'projects' if you need help.
1983 XJ750 Maxim Wiring help Projects Sep 21, 2016
Blinker wiring question Mechanical & Technical Jun 30, 2015
Turn Signal Wiring HELP Mechanical & Technical Jun 28, 2015
Anybody have a CBR wiring clip or harness? Bellingham May 11, 2015
Help wiring turn signals and brake light question Mechanical & Technical Apr 2, 2015
