Would you
Discussion in 'Motorcycle Talk' started by Chrishil54, Jun 20, 2012.
  1. use airless tires if they were available?
    Sorry, my attempt to slow down global warming by becoming a pirate has started to leak through. The r has been removed to prevent offending any of those who don't support efforts to end global warming...
  2. I'd rock some if they were cheap enough but they look like they'd cost eleventy bajillion dollars
    varment likes this.
  3. when I don't need to change air-pressure, yes.
    I'll take hard (commuting) and soft (trail) sets please
  4. On a daily driven car - sure. On a bike... hell no.
  5. RedKat600
    Don't know if I'd user them on my bike, but I'd certainly try them on my truck.
  6. Bluuu
    Bluuu Señor verde
    6,550
    11
    768
    No. Checking air pressure is the only time I get to brag about getting a knee down.
  7. assuming you could buy the firmness you want...why not?
  8. Guess we'll not talk about what really goes on Thursday nights after a few beers at the Juantia pub...
    :nana
  9. KevinD
    +1
  10. But isn't changing tire pressure strictly a function of heat management? Under hard track use, the tire heats up, which in turn heats up the air inside the tire. If there is no air in the tire to heat up, do you need to change tire pressures? I'm thinking that problem goes away if there is no air to heat up actually....
    But there is still the issue of carrying capacity of the tire based on air pressure. I'm not sure how you change the load bearing characteristics of the tire without the ability to change the air pressure in the tires.
    Still, sounds innovative, and they'll figure it out someday.
  11. As much as I'd ride a tire filled with rainbows and unicorns!
  12. Well the jury is out until they've got some real life testing. I don't know what their development progress has been, but based on the pictures it looks like that design is only going to work on 3+ wheeled vehicles that don't require rigidity from different angles. I'm sure they can and will build something that works, but for right now I like knowing what I'm riding on... I like having the ability to adjust tire pressure based on what I'm doing with my bike and what the ambient weather is like. Sure you could also buy a few sets of these airless tires and have one for each occassion, but that just seems silly. Plus I don't think it's possible to get the proper non-adjustable combinations of tire compound and structural firmness exactly right for every condition. At least with air tires you can adjust one to compensate for the other.
    I'm not resistant to change, I'm just skeptical of it :thefinge:
  13. Lol.
    It's not available now because it's not ready. Not until it's ready will i ride those tires,bur after that, hell yes
  14. DO NOT WANT!
    they won't last, Plastics are not durable enough to stand up to even one season of riding or year of driving. hit one thing that makes them deform just a little bit and guess who needs a new tire?
  15. Desired firmness is a variable based on speed & surface conditions, imo. It is not necessarily constant.
  16. I have seen somthing like this for bicycles, and they rode terrible. Felt like
    you were riding on low tires, alot of drag and real heavy.
  17. when motogp had a season on them..
  18. the tweel, good for forklifts and humvees
  19. PeteN95
    In a perfectly clean world, but in reality they will fill with dirt and mud and go out of balance and loose symmetrical flex.
  20. umm, yeah...until they figure that out and add sidewalls :nana
