Old 07-16-2009, 11:18 AM   #1
gilberjj's Avatar
I Ride: Kawasaki zx14
Speedcell Battery: Saves 10lbs over your stock battery
I have been following this on a zx14 forum for a while and I would like to add this to my steed. This battery saves an honest 10 lbs over your stock battery (these are not just manufacturer claims, many zx14 members have confirmed the weight savings). The speedcell superbike (2 row) weighs in at a paltry 1lb 7ozs. The batteries are about $250.
More info here
One vender said this about the longevity.
1000 charge to dead cycles.
They handle total discharge much better than lead acid.
In fact they were designed for this initially. AMA superbikes on the factory yamaha and ducati team are using total loss systems, with the Speedcell batteries.
No alternators, no trickle chargers, these things like 20-50 amp charge for 15 to 20 min full charge.
This battery will more likely then not outlast your bike.
Here is a video proving they start high compression bikes just fine. The 3 rows can also be had for a little more, and they can turn over higher then stock compression bikes.
Old 07-16-2009, 12:15 PM   #2
Harp's Avatar
I've been running one on my 600RR race bike for a while....at first I had the supersport battery (smallest one), but it didn't have the capacity to allow the bike to warm-up at idle in the colder weather earlier this year. I switched to the superbike battery and haven't had any problems since.
Old 07-16-2009, 04:04 PM   #3
gilberjj's Avatar
Do you know how much weight you saved over your old battery? I actually don't have one, but I'd like to get one in time.
Old 07-16-2009, 05:33 PM   #4
Harp's Avatar
I don't know exactly, but several pounds...probably in the 5-7lb. range.
Old 07-16-2009, 06:03 PM   #5
Mithras's Avatar
I Ride: 2004 SV650S
Your motorcycle battery weighs 10 pounds?
Old 07-16-2009, 06:31 PM   #6
gilberjj's Avatar
Closer to 12 actually.
Old 07-16-2009, 07:22 PM   #7
Lynk's Avatar
I Ride: a 2006 H-D XL1200C, 2005 Suzuki DRZ-400SM, 1997 Kawa Ninja 500R, and 2003 Yamaha YZF-R6 (racebike).
If I hadn't just bought a new battery for my SuMo, this would be in strong consideration! Imagine saving five pounds on a bike that weighs less than 300.
Old 07-18-2009, 11:56 PM   #8
gilberjj's Avatar
Especially on my bike where the weight of the battery is way up high.
Old 07-19-2009, 12:41 AM   #9
ApexHack's Avatar
I Ride: YZF750, 1000RR
Wow, big bike, big battery. The old Yuasa out of my 04 cbr1000 is only 6.75 lb..
Neat info. on the Speedcell. Thanks for posting.
Old 07-19-2009, 08:44 AM   #10
magista's Avatar
I Ride: Ducati S1k Bipo "Il Duce", '72 Honda 500F 'Candy Panther'
These are Lithium Phosphate batteries. They are excellent and weight savings is worth the switch. I'll be doing the deed soon.
You can make your own very easily buy buying a 36v DeWalt battery pack or going to your local hobby supply store and buying the cells from them. Take apart the pack and you will find 8 cells I believe. Create a four cell pack then wired it up (you'll have to do some research to see how to wire them). Bingo you have a "Speedcell" for about $90.00.
Speedcells or other brands of this type of battery sold through bike shops/suppliers have been marked up to an inch of their life.
Us cheap bastard Ducati owners are good for something:
http://www.ducati.ms/forums/showthread.php?t=51537
Old 07-25-2009, 09:28 PM   #11
Bike Whore
Daves929's Avatar
I Ride: Pretty much one of everything
Interesting.....
The PNW Riders riding time is 03:00 AM.
