| Zone Head Joined: Mar 2008 From: Beaverton, OR - CLAY I Ride: K6 GSXR 1K | ORP CW / CCW ? discuss Can we talk? after MANY discussions there are a few key turns that need to be pointed out in this 'safer' and 'flow-ier' CW or CCW discussion... first, let's establish some definitions... since PSSR is the only map I have seen with 16 turns, so let's use the majority rules thing on that subject - ORP has 15 turns according to their website layout, please refer to that for the following discussion as always safety first: T12... CW - if you came in too hot and couldn't stop and decided to run off, what would happen? THAT jersey barrier would stop you from falling off the 20 plus foot drop off... unless you ejected over the jersey barrier - that would hurt. T3... CW - Barn (worst case), ouch. T7... CW - imagine coming down that hill from T6, before you tip into T7, and your brakes fail... where will you run off? another ouch. now - to keep things simple, gonna use the same turn numbers for the same turns... but switch the directions. So - other direction, what's the 'unsafe' turns? none. Those mentioned above will not produce those same increased risks... Think through all the turns - ALL of them are 'safer' from a "you have no brakes" kind of run off - or a typical low side situation... Next - flow... the coolest part of the track is the half pipe. So - going CW it is a 'flat line' from T9 to T10 while the 'right line' thru CCW is to late apex both those turns. THAT causes more 'swooping', more flowing than you can imagine if you haven't done it. ADD to that - the 'entrance/exit' that T8 (CW) is... how many folks 'enjoy' entering the pipe CW? now, flip it... imagine the natural and correct drive you would have leaving UP that hill instead of driving down it and trying to mid apex T9. SO - why then does everyone say CCW doesn't flow? CCW isn't as safe???? T11 and T13. Taking T11 and 13 (15 turn track) CW is GREAT! reverse them and they are pretty terrifying! T3 is a bit of a blind left with a little downhill... well, T11 and 13 CCW are HORRIFYINGLY blind, downhill and have some serious camber challenges. T8 (CCW) Leaving the pipe, driving up that hill and flipping it back down into that trough is 'itchy'... BUT - a LOT less 'itchy' than driving down into the pipe... SO - T11 and 13 alone do increase the chance of a get off if you don't ride them properly... BUT the run off is still safe and since no matter what, folks are going to go down both ways... learning to ride those right aint any tuffer than learning T12 CW! OH - look at T12 going CCW - A LOT safer and more fun! ONE more 'safer' thing - track entrance and exit - think about it... NUFF said there. Soooo... I'm a very open minded dude with a tad bit of 'eager to learn' in me - so please, anyone that can explain why they think CW is better or safer than CCW, enlighten me? and I am NOT afraid of saying - "I was wrong" !!!! been wrong a LOT, pretty used to it, ask anybody! ![]() |
| Pit Crew Joined: May 2008 From: Vancouver WA I Ride: 2005 Kawi ZX-6R 636 | LOL, guess what Clay, remember that funny map I had that had what you're calling T12 labled at T13? Guess where PSSR got it? Yep, right off ORP's website. Admittedly, it looks like a "car" map because the driving line if that of what a car would take. But interesting nonetheless. But since I'm nice, I made you a nice pretty map with the turns labled as you are describing them above. (i.e. I added numbers in red to the ORP map) ![]() |
| Zone Head Joined: Mar 2008 From: Beaverton, OR - CLAY I Ride: K6 GSXR 1K | thread closure time... ![]() ![]() (because that 'wall below T12 is only a problem in the CW direction... soooo.... CCW=safer) also - the 'off camber' or on camber doesn't really change, what changes is WHEN you see/feel it - like entrance -vs- exit on/off camber. |
| Pit Crew Joined: Oct 2007 From: Hillsboro, OR I Ride: 07 YZF-R6 Candy Red | I've only done ORP CW and found it to be an incredible track. My personal opinion is it's an easier track than THill, but there are some who disagree with my assessment. Eitherway, ORP is the track I will definately be at the most. |
| | #9 | ||||
| Moderator ![]() Joined: Feb 2006 From: Marysville, WA I Ride: Scooty Puff Sr: The Doom-Bringer! | I've only run hard going CW, but I took my motard around for a lap going CCW. But frankly, I don't see how it's more or less "Safe" in either direction. There's more run-off that we're used to on almost all of the corners. T15 is a problem with the k-wall no matter which way you run. I really enjoyed CW, and personally I don't even have a desire to run it the other way. CW flowed pretty well. ![]()
Conversely, CCW riders are driving hard out of T2 - the race line would be far right-side of the track in order to apex T1 - exactly where exiting riders would be with their hands up. In other words, exiting riders would be perfectly in the way of non-exiting riders setting up for T1. | ||||
| Training Wheels Joined: Feb 2007 From: Beaverton, OR I Ride: 04 Honda cbr600rr | Haven't run CCW, so keep that in mind, but based on the track layout here's my opinion. I don't think it's safety issues that people complain about going CCW. It's just more technical that way. CW you have turns 3-4 and 8 and 12 that stand out. CCW you have 15, 13, 12, 11, 5 and 2 that are all become relatively more technical. Plus the straights tend to end in tighter corners going CCW than CW. That's part of what hurts the flow. Not as fun to have to stand the bike on the front wheel for a hairpin after every straight. At least it's nice to have the option to run both ways. Better riders will probably stand out more going CCW. |
| | #12 | |
| Endorsed Joined: Oct 2007 From: Portland, OR I Ride: Motorbikes | ![]()
?) followed by a late apex T15. I had more room with the launch down the straight CCW with riders exiting the track because I wasn't needing to immediately set up for another corner. One idea is to remind the riders, at least in the A group, that it's called the "hot pit" for a reason. Keep the speed up until absolutely necessary to enter the pits and then keep it moving just a bit until it's time to enter the paddock area. Don't get me wrong, my hand was unreasonably up through T13 but I wasn't letting off until past T14. | |
| Zone Head Joined: Mar 2008 From: Beaverton, OR - CLAY I Ride: K6 GSXR 1K | CW/CCW - I'm there regardless! on / off track: CW - folks are BARRELING down the straight and get within inches of the cones on the left entering T1. PSSR extended the cones all the way to the end of the entrance curbing, for safety's sake. Some one jumped out of the cones about mid hill and almost hit me Monday (that sucked). The exit... folks are putting their hands up coming out of T12 (a couple going INTO it!) to exit the track... As Deerhunter said... best thing to do is stay on it thru 13, and not apex 14. BUT - the other way -CCW... Leaving T2(CCW) would be the time to toss up a hand and stay right. PLENTY of room for faster riders to see you exiting, Plenty of room over the crest of the hill for a line of cones.... and entering the CCW direction - VERY easy to stay right and avoid any T15 traffic, then blend in at entrance to T13... Sorry guys - I just don't buy the 'safety' argument. I TOTALLY agree with tarik about it being a 'technical' thing. T11 and T13 are REALLY scary going CCW... straights into tight turns: like T12 going CW... T2 CCW becomes something like that, except you have much less of a 'down hill' drive/brake situation and you can see the entire turn from the entrance. T11 and T13, as stated, are the ugly ones... T15 CCW is actually about the same both directions from a 'blind' standpoint. T12 CCW is SOO much better though. The other 'off a straight' situation would be T5 - again, CCW is less blind but does have some downhill braking if you are pushing - but it is really wide right there (feels it anyway)... So - still not convinced CW is safer or more 'flowing' - Don't get me wrong PLEASE... BOTH are AWESOME! think it may be time for a walk around and some pictures! sounds like another trip to grass valley!!!! who's in? ![]() |
| Pit Crew Joined: Apr 2008 From: AREA54.fm I Ride: 02 Falco, 08 1098, 04 250SX, 08 X18, 99 dpcars.net 748 | I've ridden CW thus far, therefore, I'll refrain from speaking further until after I return from the Palatov double header going CCW later this month. ![]() Clay, thanks so much for the critique! It's ALL I've been thinking about since I left. Last edited by nuK; 09-11-2009 at 11:49 AM.. |
| | #15 | |
| beansbaxter is too lazy to come up with something but he will get to it, eventually... ![]() | Agree with clay pretty much 100%. When people claim there are "issues" with CCW I think they're full of shit. It's a great, safe track both ways. CCW has become an unfortunate fuzzy memory in my mind now that I've done CW 3 days and CCW only 1 day, but not only do I prefer CCW I also think it flows just fine. My conspiracy theory for the CW preference is this: It was built to be raced CW, so, of course, the racers want to stick with running it CW so they can get as much practice in before it officially opens, and who runs the track orgs? Oh ya, racers!!! It's a consperuhsee I tells ya!!!!!!! Werd. ![]()
| beansbaxter is too lazy to come up with something but he will get to it, eventually... ![]() | ![]() Eh, again, just my opinion. Last edited by OOk; 09-11-2009 at 12:23 PM.. |
| | #17 | |
| Zone Head Joined: Mar 2008 From: Beaverton, OR - CLAY I Ride: K6 GSXR 1K | actually... EXCELLENT point. ![]()
LOVE your cunspearasee thought! I've got 7 or 8 CW now and only 1 CCW... and still think CCW flowed better. | |
| | #18 | |
| Superbiker Joined: Jan 2008 From: Muk, WA I Ride: Suzuki SV1000N, XR650R, CRF450R | Couple thoughts, but I've only run CCW on the first day. First, it is an awesome track and I can't wait to try CW. The turns that scared me CCW were 7 and 15 because they are fast and blind. 7 just took a while to learn the line, but 15 is some scary shit CCW! Scraping your head on that wall and having the track fall away with a slightly decreasing double apex in 4th gear!!? There may be plenty of run off, but it would still suck bad! CW looks like more wheelie possibilities too? ![]() |
| | #20 | |
I am more scared of 6/7 CW cause you are on the fucking boil and have to commit to ONE line, praying that there is nothing stalled or slow in the way as you crest 6. But CCW you are still accelerating out of 8, so it may be just as blind, but I think there are more options as the speeds are a bit slower in comparison. But comin down the hill into the barn corner (5) is THE BEST (CCW). The camber just sucks you in, every time you realize you coulda braked way later if you had more guts! and then you flip it left and the off camber of 4 is irrelevant as the front has very little weight on it. Barn is 10 times more fun CCW. Jesus, I need to get back out there!!!! | |
| Pit Crew Joined: Mar 2008 From: Spokane, WA I Ride: 06 SV650 Street & 02 RC51 Track | I've only ridden CW, but after being to the other tracks in the NW, why are people worried about ORP? Seems to me there is at least as much runoff there as PR, SCR or PIR, if not more runoff in most places. It wasn't the easiest track to learn, but it definitely seemed like a relatively safe track to me. |
| Training Wheels Joined: Feb 2007 From: Beaverton, OR I Ride: 04 Honda cbr600rr | I think what a lot of people consider a "flowing" track is the opposite of that. One example would be having the corners link together by putting a sweeper between a straightaway and a hairpin to gradual slow down in increments rather than having a hairpin immediately following a straight. Flowing is not any better or worse, just comes down to rider preference. I'm glad PSSR didn't switch direction between the days because I wanted to really get to learn one config, but I can't wait to get a few days running it CCW. Gives us another track to play with. |
| WMRRA Qualifier Joined: Apr 2008 From: Beaverton, OR I Ride: Like an old Fart:) | Clayster, I've ridden orp Both ways and loved both although CW seems faster and has a couple Less oh shit turns than ccw. LOVE Orp!! Yeah Yeah |
| | #24 | |
.You're way fast going up the hill because you're not turning into T14 like everyone that's staying out. You've left them behind if you stay left runnning a straight line toward the entrance and haven't lifted. That's the key. Don't lift until you're clear. It's easy. | |
| Endorsed Joined: Oct 2007 From: Portland, OR I Ride: Motorbikes | ![]() Yep, I'm for gettin' back out there as soon as possible. Palatov anyone? For all of the CCW preferers.......in the current corner marshall barrier config there is an issue with running CCW. We ran CW both days at PSSR because of it. We'll have to wait and see what happens with Palatov. |
| Zone Head Joined: Mar 2008 From: Beaverton, OR - CLAY I Ride: K6 GSXR 1K | enlighten me please??? ![]() where is the issue? I was looking for it. and just re-ran my track movie... what am I MISSING?????? Phil, are you just teasing me... AGAIN? and palatov - ME WANNA! definite maybe for me right now... (but gotta wait and seeeeeee |
| Superbiker Joined: Apr 2007 From: Milwaukie, Oregon I Ride: K1200R Sport; 07 600RR | I've run it both ways and the only safety issue is turn 15 going CCW. Because of the wall you can not see around the corner and this is where riders are entering the track. Going CW you have much more time to see the traffic entering the track and deal with it, as long as they stay to the outside of turn one. As for the rest of the track it's just a matter taking your time to learn it in either direction. Personally I think CCW is a little more technical and it's my favorite direction. |
| | #28 | |
| Pit Crew Joined: May 2008 From: Vancouver WA I Ride: 2005 Kawi ZX-6R 636 | ![]() From their website: ![]()
| | #29 | |
| Zone Head Joined: Mar 2008 From: Beaverton, OR - CLAY I Ride: K6 GSXR 1K | ![]()
agree with underlinedisagree with red - as long as those coming on follow the RULES, there's no issue... and you know going CW someone decided to just pop out onto the track thru the cones and almost knocked into me at 130 or so... sooo - from THAT perspective (rule breaking) either way is pretty freaking SCARY. PHIL - what's the issue with corner stations going CCW??? | |
| | #30 |
| Sweep Crusader Joined: May 2009 From: Portland, OR I Ride: ... "sweep." | Phil, I'm going to TRY to get in for Palatov... can I paddock with ya again? (I'll bring my generator again, so I don't go out on COLD tires IF you forget to plug them in again... ) I'll see if I can't drag Brian out again, too.Sax |
| | #31 |
| Training Wheels Joined: Nov 2007 From: Lake Oswego, OR I Ride: Ducati 1098, Honda CRF450r | I've ridden both direction. Personally, I prefer counter clockwise both from a safety and fun factor. Counter clockwise is harder to ride a liter bike fast than clockwise (down hill braking vs. uphill braking). The biggest safety problem (and an easily fixed one) with ORP is track entry and exit in either direction. There doesnt seem to have been much thought about track entry and exit considering how the hot pit and front straight are designed/constructed. Clockwise, the track exit is relatively easy and safe. Track entry is a complete mess. The hot pit road and merge is far too short and without cones dumps you out onto the front straight on the fast line with no room for error. Extending the cones down, like PSSR did, is a quick fix but not a real solution. The real solution is the widen and pave the track entry and/or front straight so that you are not putting vehicles and people so close together at such dramatic speed differences. Turn 15 coming onto the front straight is a problem. It is never safe and shouldnt be acceptable to point your bike at the corner of a wall for an apex point. Much work needs to be done there. Counter-clockwise track exit is smooth and easy, but would work better and be safer with increased paved area where vehicles get off the track and away from the vehicles continuing at speed. Turn 1 is gnarly, again pointing at a wall at an even higher speed is never good. This direction is safer for the track entry considering that a fast line through there pushes you to the left of the track and the track entry is on the opposite side of the track. However, additional pavement and barrier here would be much better. Other issues are the run-off irregularities (easily fixed with a couple days and tractors) and pavement seams (not such an easy fix). The pavement seams are quite deep and wide in some of the corners. Over time, cars will make these far worse. Cones used to mark certain aspect of the track need to be placed by someone who knows what they are doing. Back in April at my event, when we arrived the cones were placed in random and wrong areas. Much time was spent surveying the course and sight lines and placing the cones. The track should consider some semi-permanent cones like Miller has in marking some of these areas. From a customer service point of view, the track has alot to learn. Full port-a-poties, garbage cans, lack of water, power, etc. There is no excuse for full port-a-potties, garbage bins/cans during an event. Its not like this was a spectator event, just a trackday. People remember things like this. People are willing to forego some creature comforts if the price is right. But the price isnt right. I can rent the full course at Miller for the same price as ORP. Does that make sense considering what you get for your money? For what you get, ORP trackdays should be $120-150 max, but because the rental is so high, the pricing is past down to the customers. Build permanent bathrooms/showers, increase track safety, larger paved paddock (far too small currently), better track control system (need a tower), install a PA system, 21st century control radios (not radio shack walkie talkies), have running water and electricity then charge what you charge. There is more to running a track than just putting pavement down and saying you're open for business. Imagine what the rental rates will be once these things are done? A facility should be able to 'objectively' look at an evaluate their product and price it accordingly. I know it is expensive to pave and do the things that need to be done. But charging Marriot prices with Super 8 quality/ammenities leaves you with ALOT of vacancies. |
| | #32 |
| Training Wheels Joined: Jul 2009 From: Lake Oswego, OR I Ride: Whatever I Can | Orp Regarding ORP in its current state: The biggest element of safety can be managed by what's between the ears of the rider or driver. It is simply not worth trying to go fast when you don't know where the track is headed or take any unnecessary risks in either direction that will only net a bad result. If you keep your riding or driving in perspective and treat the course with respect there is a lot of opportunity to refine your skills and do it safely in a controlled environment, RIGHT NOW. |
| | #33 | |
Ya I hear what you're saying, makes sense. But coming out of 14 WOT to stay outta others way, with my hand up entering the "hot pits" is not how I feel comfortable comin off the track. Every other track I've ridden (which is not admittedly a lot) you come off the racing line and pace at least 1 or 2 turns before pitting. I'll keep putting my hand up after 12 until the race orgs start saying that's incorrect and dangerous. Oh noez, stop picking on me ya jerk!!!!! No worries! | |
| | #34 |
| Training Wheels Joined: Apr 2007 From: Seattle, WA I Ride: slowly round and round | [QUOTE=OOk;1861238]Ya I hear what you're saying, makes sense. But coming out of 14 WOT to stay outta others way, with my hand up entering the "hot pits" is not how I feel comfortable comin off the track. Every other track I've ridden (which is not admittedly a lot) you come off the racing line and pace at least 1 or 2 turns before pitting. I'll keep putting my hand up after 12 until the race orgs start saying that's incorrect and dangerous. /QUOTE] I agree. At the most recent PSSR event two of us who were charging hard up the hill and passing on the outside in 14 almost ass packed an exiting rider when he threw up his hand after 13 and promptly exited. Track exit should always be indicated early where there is a good line of site and then the overtaking rider has the responsibility of adjusting his/her line as needed. |
| | #35 | |
| Zone Head Joined: Apr 2007 From: Out of your mind I Ride: like it’s gonna rain tomorrow. | ![]()
And my vote goes for CCW. ![]() | |
| | #36 |
| Zone Head Joined: Mar 2008 From: Beaverton, OR - CLAY I Ride: K6 GSXR 1K | sooo - a brief look at this thread tells me a couple things: 1. Phil is off at a track somewhere and can't respond right now because his statement about a 'corner worker station' issue when running CCW is the ONLY thing that suggests there is a 'safer' way around ORP. 2. of those responding, it appears CCW is actually the preferred direction. sooooo - 3. I suggest the next ORP events be ALL CCW!!! ![]() (REALLY hope I can make them!) |
| | #37 |
| Endorsed Joined: Oct 2007 From: Portland, OR I Ride: Motorbikes | Back online. Got beat up pretty bad by Ken Hill at TH . Looks like I'll be goin' slow for awhile .The track manager tells me they arranged the barriers at the corner marshall towers to protect them from cars. There still has to be an open space in the barrier for ingress/egress and the configuration left them unprotected when running CCW. He knew that safety was jeopardized CCW with cars and suspected it might be with bikes as well. He made the CW requirement public at the PSSR event. I let Morgan know this and perhaps they have decided that it is not a problem with bikes. However, if they still see it as a problem with cars, then I doubt Palatov will run the cars CW both days and the bikes CCW on one of them. |
| | #39 |
| Endorsed Joined: Oct 2007 From: Portland, OR I Ride: Motorbikes | ![]() I threw that cord out but bring the generator anyway (with a really long extension cord). I actually think it was Brian fuckling with ya' 'cause his were warm . Hope to see you there. |
| | #40 | |
| Zone Head Joined: Mar 2008 From: Beaverton, OR - CLAY I Ride: K6 GSXR 1K | .... ![]()
![]() ![]() Thanks Dr. Phil!!!! ![]() now - about getting 'beat up'... You want I should go talk to this guy? ![]() ![]() I am TRYING to get to ORP for palatov!!!! seeya'! C | |
