Old 10-08-2009, 10:44 PM   #1
raceface's Avatar
I Ride: 2006 R6
What Causes A Low/High Side?
My limited understanding tells me a high side is a loss of traction resulting in a slide followed by a violent return of traction.
That's all well and good, but what can be the causes of that initial loss of traction? CG? Power? Braking? What can I do to prevent it.
Same for low sides and front tucks. What causes them and how to prevent them?
Many thanks oh great ones.
Old 10-08-2009, 10:53 PM   #2
odin544's Avatar
I Ride: '08 Ducati 848 street , '03 R6 race (for sale), '07 R6 race
You're full of questions tonight huh? LOL
I'll let someone with more experience answer this.
Old 10-08-2009, 10:56 PM   #3
raceface's Avatar
I Ride: 2006 R6
Yep. Figured winter is a good time to brush up on the knowledge. Starting now. Thanks for your input on that other thread. It seems the more I find out about this stuff the more of a dark art it is.
Old 10-08-2009, 11:02 PM   #4
mcjunky's Avatar
I Ride: rz's, rd's, kx's, nsr's, rx, yz with a little zx thrown in
pissed off chassis
Old 10-08-2009, 11:05 PM   #5
raceface's Avatar
I Ride: 2006 R6
K, that's a start.
Old 10-08-2009, 11:05 PM   #6
MikeM's Avatar
It's to late.... I'll tell you in the morning :-)
Old 10-08-2009, 11:12 PM   #7
raceface's Avatar
I Ride: 2006 R6
Yay!
Old 10-09-2009, 02:27 AM   #8
Fast Eddie 919's Avatar
I Ride: 04 Kawi ZZR 1200
Cold tires.
Old 10-09-2009, 07:20 AM   #9
Transported's Avatar
I Ride: '99 R1, '80 Suz GS450S
Highsides: 1) rear braking causing a skid, then letting off the pedal; 2) acceleration causing slide, then chopping the throttle off.
Old 10-09-2009, 07:43 AM   #10
MikeM's Avatar
There are a ton of different reasons you might encounter one of these problems and a bunch of different variables but here are the main reasons providing you are on decent tires, your suspension and chasis is set up correctly and you are being smooth with your input.
Lowside: The cause is that you are asking too much from the front tire. You can do this by trail braking too deep or more commonly is that you actually rolled out of the throttle when you should have stayed neutral throttle or slightly positive. I would say 90% of lowsides you'll see at a trackday could have been saved had they been on the gas rather than closed throttle or brake. That's why you'll see the fast people back on the gas as soon as they are done braking. It transfers some of the weight back to the rear tire so that you can use more front tire traction to complete your turn.
Highside: There are a couple ways you can highside, either on the gas or the on the brakes.
If you highside on the brakes its normaly from grabbing a downshift dumping the clutch and the back starts to slide. You should be slowly letting the clutch out and feeling for available traction when down shifting. Slipper clutches are your friend!
The typical highside if from too much throttle coming out of a corner. You need to be very smooth when rolling on the throttle coming out of a corner while you are feeling for traction. (this is harder if you have both cheecks hanging off hell bent to drag your knee :-)
If the rear tire start to slide you should not chop the throttle but maintain it, weight the outside peg a little while working on standing the bike up untill you are back in line and then continue to apply throttle. When you chop the throttle is when you run into problems.
Again, there are a ton of variables that can contribute to either one of these, but these are big contributing factors.
Old 10-09-2009, 08:51 AM   #11
Beast to be Unleashed
D_Rail's Avatar
I Ride: 2006 Suzuki GSX-R 750
Originally Posted by Fast Eddie 919 View Post
Cold tires.
Such a common thing to blame things on. But no!
Old 10-09-2009, 09:28 AM   #12
theJrod's Avatar
I Ride: Scooty Puff Sr: The Doom-Bringer!
Lowsides = catastrophic loss of traction (I say catastrophic because a loss of traction alone != a crash. You can save a front end or rear end slide a lot easier than people think).
Highside = major loss of traction (of the rear, usually) followed by a sudden regaining of traction. Weeeeee.
Edit: I almost forgot - any highside or lowside is 100% because of poor tire choice. Yeah. Or it's another rider's fault.
Old 10-09-2009, 09:39 AM   #13
Hypnotiq's Avatar
I Ride: Race: 06GSXR750 - Street: 09 Eight Four Eight
. Don't forget cold tires or overriding the equipment.
Old 10-09-2009, 09:51 AM   #14
BoBo's Avatar
I Ride: Aprilia RSVR Mille
Simple answer....
Lowside - caused by loss of traction while cornering
Highside - caused by loss of traction and then restored traction under heavy acceleration. Violent fish-tailing
Old 10-09-2009, 09:54 AM   #15
I Ride: In search of the next 35mph corner......
Great info.. but a lowside can also be the result of asking too much from your rear tire as well..
Sept of last year at SRP, T7... wrong line (outside-off camber) and too much throttle on good, warm tires.. she went down so stinkin fast it was amazing.. one second I was goin thru the corner..next I was sliding down the asphalt..
PURE rider error.
Old 10-09-2009, 10:03 AM   #16
firecracker's Avatar
I Ride: GSXR 1000 K9 and GSXR 1000 K9
This past summer I learned a ton at the Sullivan Race School. One of the things I learned was to ride at very, very, very high rpms to avoid highside falls. If your rear begins to spin and you're at 11,500 or something close, you can roll on the throttle slowly without giving the rear too much power. If you're riding at medium or low rpms, you're more likely to highside when your rear begins to spin and you roll on the throttle...the rear catches with a lot of power at low or medium rpms, tossing you up and over. I think this saved me on cold tires in turn 1 at PIR later on in the year!
Old 10-09-2009, 10:47 AM   #17
I'm a little perplexed by this response. I see you are a more experienced rider than I am so I would be interested to hear you elaborate. I thought it was a factor in a highside I had a few years back, I have had several friends 3 other guys, and myself, and many others who have related to the same or similar experience. You pull out of the drive way crack the throttle and the bike swaps ends on you, these were all late model bikes with good tires on them.
Old 10-09-2009, 11:07 AM   #18
theJrod's Avatar
Cold tires do offer less grip - that is true.
However, the blame lies on the rider for asking too much of a cold tire. Modern tires have so much grip when warm, that they mask/hide a lot of errors riders are making. You can get away with being jerky on the throttle because the tires are so sticky. If you're smooth on the inputs, cold tires really aren't that bad. This is why riding in the rain is such a great learning experience. Any sudden inputs or jerkiness is instantly known!
Old 10-09-2009, 11:44 AM   #19
ducatiduane
the chemist's Avatar
I Ride: but not on the street.
most of the time you go down, its your fault. there is the occasional time were shit just happens and theres nothing you can do. oil spills, starts raining mid session while you're on DOTS and a corner is super wet, someone kicks gravel all over a corner...
if you're smooth you can feel the traction go away on the rear. if you get on the throttle smoothly and the rear starts spinning, you can bring it back, because it wont have stepped out too far. if you just whack the throttle, its going to slide out all the way and flick you to high heaven before you know what happened.
another cause of crashing is releasing the clutch too fast on a start.
Old 10-09-2009, 01:49 PM   #20
MikeM's Avatar
I don't think there are going to be that many people pulling that particular crash off....
Old 10-09-2009, 01:56 PM   #21
MikeM's Avatar
What I've always found interesting about this concept is most bikes make more power the higher up in the rpm range you are. So this doesn't really make sense to me.
I know that on my bike there are a couple of corners I take in second rather than 1st just so its easier to manage traction and wheel spin.
Old 10-09-2009, 02:17 PM   #22
chaeric's Avatar
I Ride: while I'm young
I was at ORP following Paytheon for a number of laps. Everything was fine, but at a corner that led to a fast straightaway when I used too much gas the rear started stepping out quite a bit. For some reason I thought to decrease the throttle by 30% or so ...and like as everybody has mentioned above the rear suddenly caught traction and I nearly highsided, and did a mini-tank slapper.
Which reminds me. I relaxed my arms, and the tank slapper went away, but then I learned that my brakes for some reason didn't work so I had to pump them a few times. So if you get a tank slapper remember to pump your brakes after you regain control.
Old 10-09-2009, 02:46 PM   #23
Paytheon's Avatar
I Ride: 07 YZF-R6 Candy Red
Man, I'm glad you got her under control.
Old 10-09-2009, 03:02 PM   #24
The amount of torque on a GSX-R1000 does seem to begin to decrease quite drastically around 10,000 to 11,000 rpms, and especially around 12,000 to 13,000 rpms, but I know what you mean...it's great in concept, but maybe not in practice. The high, high revs. seem to upset the bike quite a bit, especially if the bike is in 1st. EmDee takes T4 in 1st, which seems pretty nuts to me...and that's on a 600 that's pretty "jumpy" in 1st!!!
Old 10-09-2009, 03:10 PM   #25
MikeM's Avatar
You have to take that corner in 1st on a 600 otherwise you have to get off and push for a while until the thing spools up enough to make any power.
The reason people go into a corner with the revs high is so that they get a good drive coming out....
Old 10-09-2009, 03:55 PM   #26
NoQuarter#121's Avatar
I Ride: on ice at 15F below zero
I take T4 in first... its T5 I've been having problems with lately....
Old 10-09-2009, 04:36 PM   #27
stevieb's Avatar
T4 in first??....no wonder I'm so damn slow
Someone remind me about this come March 2010 cause I'll forget and spend all next season pussy-footin around it in 2nd
Old 10-09-2009, 06:27 PM   #28
raceface's Avatar
I Ride: 2006 R6
I just found this while sifting around online. Seems pretty informative.
http://www.msgroup.org/forums/mtt/to...?TOPIC_ID=2192
Old 10-09-2009, 06:33 PM   #29
nocontrol74's Avatar
I Ride: 06 SV Race Bike - As soon as I have a job...
I can attest that this is the truth. Don't do it. It hurts and it's expensive.
Especially don't do it twice. On consecutive corners. On consecutive track days....
Old 10-09-2009, 06:46 PM   #30
Wrench's Avatar
Sand or gravel on the road.
It's the only reason anyone ever looses traction and has an accident...
Old 10-09-2009, 07:09 PM   #31
odin544's Avatar
LIES its those damn tar snakes! they jump out at ya!
Old 10-09-2009, 07:22 PM   #32
ducatichick's Avatar
I Ride: 08 Hypervibrator
If you drag anything unforgiving, like an exhaust or fixed footpeg, you can lose traction. One time in a race back in '99 some guy hit my exhaust and bent it down - I didn't know (heard about it later), took the next left hander, dragged the exhaust, then highsided. All I remember was flying through the air, waking up face down in the dirt, then staggering around looking for my bike. Took me a few minutes to find my bike and it was pretty messed up. Talked my way out of an ambulance ride. I recommend against highsiding.
So basically, it's the other rider's fault!
Have you read the Keith Code books? Titles are A Twist of the Wrist 1, 2, and Soft Science of Motorcycle Racing. They might be helpful since he explains some of the things that can cause lowsides etc.
Old 10-09-2009, 08:00 PM   #33
Deerhunter's Avatar
I Ride: Motorbikes
EASIER SAID THAN DONE, EH?
Old 10-09-2009, 08:23 PM   #34
bigtbone's Avatar
I Ride: Ducati 1098, Honda CRF450r
I've lowsided many times and high sided a few. The highsides are infinitely more painful physically and do more damage to the bike.
EZ Definition: Low side means you hit the ground first. Highside you are still in the air while your bike is on the ground.....it very surreal watching stuff 10' beneath you while you wait for the pile driver to hit.
Old 10-09-2009, 10:21 PM   #35
WTFO's Avatar
If I remember some comments by Keith Code in one of his books he stated to the effect that most folks cause a tank slapper to result in a wreck because they fight it versus letting the chasiss actually sort it out by in essence "letting go of the clip ons" so to speak.
Old 10-10-2009, 05:02 AM   #36
Deerhunter's Avatar
I Ride: Motorbikes
"Fighting it" transfers the energy of a headshake to the chassis through your body. Bad. Loosening your hands lets it dissipate up front which, they say, is a good thing.
Old 10-10-2009, 07:43 AM   #37
Hypnotiq's Avatar
Really Stevie? You didnt know this? I'm sorry... :(
Old 10-10-2009, 11:36 AM   #38
chaeric's Avatar
Well I actually grabbed the handlebars so I wouldn't be flung off the bike...if I didn't do it I probably wouldve fallen off. It did however start a tank slapper. However, I did exactly what you and Deerhunter said and the situation resolved itself.
Old 10-10-2009, 02:45 PM   #39
ducatiduane
After you chop it and have a huge high side, you learn the lesson. Although it is hard to stay on the gas when the back just keeps coming around...you actually have more of a chance of saving it if you stay on the gas. there have been a couple times now were i had to consciously tell myself to stay on the gas (and I saved them somehow). if you chop it you're a goner. after you do it once and get transported, you learn
To be added to Tyson's statement:
Lowsides tend to happen fast. Its "you're going through a corner, feel the front go, and youre in the air fence". High sides on the other hand...are more like "I felt the rear slide, about 30 minutes later it hooked and tossed me. I watched the bike go flipping, found a cure for cancer, solved world hunger, and made a sandwich. then i got hit by a train, which was followed by a bus."
Old 10-12-2009, 11:56 AM   #40
raceface's Avatar
I Ride: 2006 R6
Thanks for all the information guys. I know I haven't said much but I really appreciate the input. This is going to help.
The PNW Riders riding time is 12:49 PM.
