| Licensed Joined: Sep 2009 From: Spokane, Wa I Ride: Yamaha | School me on Downshifting So as my quest for quicker laptimes continues, i find that the weakest part of my track skills are setting up for a corner. one track day i practiced revmatching and got it down but after being followed by faster racer friends i was encouraged to just abuse the slipper that my r6 has. Indeed that did simplify things and my corner setups were faster but still feel slow. i watched a onboard lap with Josh hayes on his r1 and i am amazed at how fast he downshifts. obviously he is light years above my skill level but is he really revmatching that fast? going clutchless? School me |
| Pit Crew Joined: Oct 2007 From: Miles from here I Ride: badly | I think Josh might have better tires, suspension, brakes, chassis, gearbox, clutch and a larger displacement than your R6 but that would be a wild guess. he might also have a little bit of skill and practice at this gameI am not fast so don't listen to me or read beyond this point. What I have noticed at trackdays is that the last of the late brakers are really smooth on the brakes. When I try to downshift hard the backend of the bike feels really unstable on an inline 4 but never out of control, on a big twin the engine braking is to be used with respect. Both of mine are minus a slipper, if your clutch is setup not to lockup the rear and you don't mind abusing the engine go for it NB: On a modern sportsbike the vast majority of braking when in a straight line is on the front tire. |
| Licensed Joined: Sep 2009 From: Spokane, Wa I Ride: Yamaha | oh i understand completely the bike diferences. Also i never touch the rear brake. just seeing what tips and tricks everyone else is doing or if i just need to practice more. The one technique i have never been able to wrap my head around is blipping while hard on the front lever. |
| Chicken Strips Joined: Jan 2011 From: Portland, Oregon I Ride: 2002 honda 919/cb900f/hornet: the REAL naked bike.... | I shift down as my speed drops due to braking. Pay attention to the engine, find that sweet spot where the engine easily shifts down without losing too much rpm but still allows you to use engine braking at the same time as soon as you let out the clutch. |
| Permit Joined: Apr 2012 From: Oak Harbor I Ride: 00 RC51 #1119 / 97 CBR 600 F3 | As far as the track and downshifting I have pondered the same thing. The best answer I found was on "Twist of The Wrist 2" They explained it very well (Simultaneous Braking hard on the front while blipping the throttle and downshifting) ultimately its something that just takes lots of practice (on the track). If you watch racing, they all do it and there is no way around it if you want to be any good. As with anything you want to master, just have good form and technique, take your time and do it right. it will come. ON the street, I never touch the rear brake. I hardly brake at all unless I'm coming to a stop. I downshift to slow down or lose speed. NOt saying thats right or not but I have seen people clutch in and brake to a stop at a redlight from 5th or 6th gear and not downshift. right as they stop or almost stop the light turns green. Cars are coming and now they can't go anywhere until they find first . Or the bike stalls out cause they panic. Disaster!!! |
| Moto2 Champion Joined: Mar 2006 From: spokane, wa I Ride: 2008 SXV4.5 + 1985 RZ350 + 2010 YZ250F + | I would just abuse the slipper. It's a tool, so put it to good use. It's job it to keep your mind on the important stuff. Also, once you find a brake marker, brake for everything you are worth. Once you realize where this puts you, back on the throttle to get to the corner, you can move that brake marker further back. The other thing is to make sure that your mind is up to speed before trying to go faster, quickly. |
| Chicken Strips Joined: Aug 2010 From: Federal Way, WA I Ride: in a vanpool | A friend once told me "body, brakes, gear, gas" in relation to setting up for a turn. The message was about separating these actions and minimizing the number of things you do at once while setting up. If you brake then shift the yank from downshifting should be considerably reduced so your slipper can easily take the pull. As you play around with this you should start to get a feel for which gear you need to drop to for any given corner. |
| Streetfighter Joined: Feb 2010 From: Seattle, Wa I Ride: An 06 R6 with OPRT | Depending on what year your R6 is, there are a couple mods that will help your "kinda worthless" slipper act more like it should. Flashtune can adjust how much engine braking there is, or you can do it mechanically by shaving 2 of the springs in your clutch. I'm doing flashtune because it also offers other advantages, but if you just want to have more slip, shaving the springs is what the racers do. http://www.r6-forum.com/forums/showt...=36545&page=12 |
| | #10 | |
| Licensed Joined: Sep 2009 From: Spokane, Wa I Ride: Yamaha | ![]()
| Streetfighter Joined: Feb 2010 From: Seattle, Wa I Ride: An 06 R6 with OPRT | I'm not sure, I don't think so, but I could be wrong. Best to call him and ask. He is also authorized to do Flashtune now as well. |
| Novice Racer ![]() Joined: Mar 2006 From: medford, oregon | ![]() listen to the podcast I did with him about UCU unleashed and get to a track school |
| | #13 | |
| Licensed Joined: Aug 2008 From: Battle Ground, Wa. I Ride: Not enough... | What did you learn that changed the way you think? |
| Training Wheels Joined: Sep 2012 From: Portland I Ride: 05' GSXR600 Anniversary | On the track you need to master braking, hard, with two fingers, while blipping the throttle with the palm of your hand. IE coming into turn 1 at PIR for example, you should be able to get on the binders hard, scrub over 100 some MPH, while dropping three gears, and doing so with the RPM's matched. 0 clutch dragging allowed, or over-revving and lurching the bike. If that sounds tough, it's really not, you just have to practice. You should also be able to bang off a shift mid corner (not ideal) if you have to without upsetting the chassis, that means rev-matching. Very important you get it bang on or your could fuck up your line. |
| Endorsed Joined: Aug 2008 From: Lake Oswego | On the R6, clutch setup and ECU work can make you a rockstar, you can even flash a auto blipper into the R6 which will blip the throttle for you on a downshift. Technology aside, its a skill you should learn as a rider and only tracktime and practice will cover that. |
| Licensed Joined: Feb 2012 From: Tukwila I Ride: 2007 Ninja 650R | I'm still trying to get this down. I've had a couple scary calls and almost launched the bike from blipping the throttle and letting the clutch out wrong. So lately I've just been braking enough to the speed I want for the gear, then clutch in, and then downshift without letting off the throttle. If I do it correctly, I don't notice any lurching or drag. However, this is on the street, so I have no idea how it would translate on the track. Also, as mentioned by others, I normally engine brake and downshift to slowdown like to a light, so by the time I do come to a complete stop, I'm already in 1st gear. I'm still a noob, so I'm still learning. |
| Chicken Strips Joined: May 2008 From: Ross Ice Shelf I Ride: into town a-whompin an a-whoopin | At the STAR school we learned that downshifting is one of the most overlooked aspects of riding fast. Forget blipping. When you are truly hard on the brakes, you won't be able to do it right. None of the really fast guys (AMA, SBK, GP, etc) blip. Downshift pretty much right away. Bang Bang Bang. This eliminates the need to blip. If you brake first and then shift you have to blip. If you downshift at the same time you don't need to. Even if you have a slipper, you should still modulate clutch with your left hand. Fast riders have slow hands. There's a shitton more, but you'll have to take the school. |
| Permit Joined: Jul 2008 From: Kirklandia I Ride: '10 S1000RR, '08 K1200GT | Jason Pridmore teaches shifting down first, literally as soon as gas starts to roll off at all. He's big into engine braking and smoothly releasing the clutch to manage RPM. He advocates keeping the motor at high revs and no blipping. One byproduct of this is that you get more of your work done before the corner and you have less to think about. Also, any mistakes in shifting, and you have more time to correct. I was using more of the Code style of brake and shift together and I found Pridmore's technique to be quite effective, especially on an I4 with a good slipper where overrevs just really aren't much of a problem. A lot of what Pridmore teaches has to do with economy of motion, which makes sense considering his background of endurance racing. |
| Licensed Joined: Aug 2007 From: Moscow, ID I Ride: slow on fast bikes, and slow on slow bikes. | I don't have much to add here that hasn't already been said. I do think it's cool how many racers (even really fast ones) have chimed in on this thread already. My primary recommendation would be to pull one of the control riders aside at the next Inland Speed track day and have them shadow you for a few laps to study exactly what you're doing as you set up for a corner. They will be able to give you lots of tips based on what they see. There's a lot of intermediate steps to get from where you are now to what Josh Hayes is doing, and I think a good instructor will be able to identify what things to work on next. As a general practice, I blip the throttle on nearly every downshift while street riding. Not because it helps with anything I'm doing on the street (usually just coming to a stop). But it builds that practice to the point where it becomes almost automatic. Eventually this behavior becomes a natural thing that doesn't require any significant additional concentration. I do have slipper clutches in both my R6 race bikes, and occasionally I don't blip the throttle and just let the slipper do its thing. The slipper helps a lot compared to no slipper, but even with the slipper I can feel the back stepping out a bit, so I end up divirting some attention to modulating the clutch lever in those cases. The main place I've noticed myself not blipping is entering T2 at Pacific Raceways. If I'm trying to outbrake someone I sometimes don't blip (three downshifts for my bikes). -Dan |
