Old 11-04-2009, 07:49 AM   #1
micknwop's Avatar
I Ride: Therefore, I am!
2 stroke jetting
So im working on a 2001 cr250r. It has a procircuit pipe. I'm trying to figure out a good jetting for seattle elevation (or close), and also climate.
It is currently running
22.5
420
6beh2-76 on the 2nd clip from top
And, where can i get just a few jets to try it out without buying a whole set?
Cheers
Old 11-04-2009, 09:34 AM   #2
I Ride: GSXR600, CBR600, YZ444, RZ350
I buy my jets at Lake City Powersports. Aurora Suzuki more than likely has them as well, but Lake City is closer to me. Walk in with an example of the pilot and main, just because.
I don't know what you will run for specific jetting, but I wouldn't worry about needles right now, get the main and pilot close then work on needle. A lot of issues can be dialed around the needle. Do you have a mixture determined yet? What about gas, pump or race? Oil brand?
Old 11-04-2009, 02:28 PM   #3
micknwop's Avatar
probably 31:1 with honda red bottle.
both of those places are reasonable distance.
research shows most people running around 30+ and 400. Maybe i need to pick up a few jets
Old 11-04-2009, 03:01 PM   #4
Mr. PNW Riders 2007
erickb's Avatar
I Ride: without gear
give me 2 beers, 5 min and a test ride and jets will be the last thing you will need to fix
side not I went through a lot of jets on my RM until I found one that worked, I have no idea the size but I kept changing them until I liked the way it rode
Old 11-04-2009, 04:50 PM   #5
32:1 is a lot easier to mix than 31:1. A side note is that 20:1 made the most power, but make sure that you are mixing according to the bottle. For example, don't run a 40:1 oil at 32:1, or vise versa. It took me the better part of a day to get my RZ even close to rideable, but with the baseline sorted it is a complete blast to come on the pipe.
Are you comfortable with jetting? Do you know what you are looking for? I have a bunch of links somewhere that I pored over when I was building my RZ. If I find them I will pass them along, unless, of course, you know what you are doing upon which time I will STFU.
Just remember that adding more oil to the gas will make the bike run leaner on a particular jet size. Basically, if it is hot out and you don't want to mess with jetting just add more oil to the mix. Conversely, subtract oil form the mix if it is colder. The oil will displace fuel during the combustion process. Just food for thought.
Old 11-04-2009, 05:55 PM   #6
I Ride: 03 ZX636, 90 FZR400, 97, RS125, 98 RS125, Z50!
Whatcha need?...
I've got some mains and pilots you can try if you like. Oh...and you're welcome to a bottle of Motorex 2-stroke oil if you like. I like redline for my dirtbike and A747 for the RS125s.
Does this mean we get to go dirtbike riding when you get it sorted out?
Old 11-04-2009, 07:49 PM   #7
micknwop's Avatar
im not an expert but i know when something isnt running how it should. Im doing a small tear down since the bike has been sitting for a while. First time it's seen sea level so im sure i need to change the jets, figured id do it while its apart.
Originally Posted by Alanjtc73n View Post
Whatcha need?...
Hmmm, i would venture i'd need in the realm of 390, 400, 410.... and also 30 and 32 i would gues.
anything else you want to give me
and yes, i need to change the fork seals, greese some bearings, get a chain, rejet, and maybe some tires. Then we're she's good for a trial run.
Old 11-04-2009, 09:21 PM   #8
It sounds like you have "carburetor 2". Are the mains slotted? I've got a whole assortment of the hex but only a few of the slotted. I'll take a look and see what I've got. The 420 main you got is good for a stock bike at sea level. Your slow jet sounds weird. They should go from 25 to 45.
Old 11-04-2009, 09:35 PM   #9
coastiepete's Avatar
I Ride: 2007 ZX-10R SE, 2005 450 EXC, 1980 GS750 Cafe Project
Whatcha need?...
Redline FTW. 50:1?
Old 11-04-2009, 09:48 PM   #10
Motoxfox12's Avatar
I Ride: CBR600RR
thats too lean for an 01 CR^
Old 11-04-2009, 09:52 PM   #11
ahhh. that's what we were running on an RM.
Old 11-05-2009, 05:59 AM   #12
You mean rich, right? Too much gas, not enough oil.
Old 11-05-2009, 08:11 AM   #13
Doom Crew Inc.
StageRulz's Avatar
I Ride: 2002 Silver/Grey & 2008 Black/Grey Vespa's on Steroids!
WoW.....there are some really "Keyboard Jockeys" play'in tech around here.
Old 11-05-2009, 08:13 AM   #14
micknwop's Avatar
the main is a hex, but the slow jet is a slotted. I'm gone this weekend, i'll give you a ring maybe we can meet up next week.
Im open to more suggestions.....
Old 11-05-2009, 09:07 AM   #15
How so? Most of the posters either have experience jetting a two stroke in general, or a CR250 in particular. How is that being a "Keyboard Jockey"?
Old 11-05-2009, 09:34 AM   #16
50:1 can be run okay if you want to try to get the most power out of it. I believe the manual says to run 32:1. My CR125 runs 20:1. It's a little smokey but works well for woods riding. I just replaced the top end this weekend and the cylinder has no wear on it. The piston had some blow-by but everything else looked great. I'm sticking to 20:1. If you plan on doing top ends more often, then you can get away with 50:1. If you don't want to hone out your cylinder every top end then run it closer to 32:1. All depends on what you want to do with it. If you're putting in a new top end, you should run it with more oil and a slightly bigger main as it breaks in. Then you can taper off and rejet if you want more power.
Old 11-05-2009, 11:17 AM   #17
Hawker's Avatar
I Ride: Too many
Try reading this and understanding how to determine where your jetting is at, rather than looking for settings on the internet. More than once even experienced tuners have given me jetting settings that didn't work at all on one particular bike. Knowing how to diagnose jetting is a good skill to learn : http://www.thumpertalk.com/forum/sho...d.php?t=412662
Old 11-07-2009, 09:19 AM   #18
Originally Posted by hawker View Post
try reading this and understanding how to determine where your jetting is at, rather than looking for settings on the internet. More than once even experienced tuners have given me jetting settings that didn't work at all on one particular bike. Knowing how to diagnose jetting is a good skill to learn : http://www.thumpertalk.com/forum/sho...d.php?t=412662
holy info!!!! Nice post dude!
Old 11-07-2009, 09:55 AM   #19
dakh's Avatar
I Ride: the walk
1:20 Do you repack the muffler on that thing after every ride?
Old 11-07-2009, 12:57 PM   #20
Funny you would say that. I'm on my way to grab some packing. Yes, it does get a little bit of spooge but my buddy that rides it is a noob. Although I'm sure the worn top end didn't help. It's never been a problem for me in the past but I don't ride it anymore since I got the 450. I'd rather it have too much oil than too little. He has a little problem of either not being on the gas enough or too much and being a little slow on the trail heats it up pretty good. The 20:1 prevents me from having to replate the cylinder. Plus, the manual recommends 20:1 but I know that's super conservative. I figure you can't really go wrong with what the manual says.
Old 11-07-2009, 01:01 PM   #21
dakh's Avatar
I Ride: the walk
Funny you would say that. I'm on my way to grab some packing. Yes, it does get a little bit of spooge but my buddy that rides it is a noob. I'd rather it have too much oil than too little. He has a little problem of either not being on the gas enough or too much. The 20:1 prevents me from having to replate the cylinder. Plus, the manual recommends 20:1 but I know that's super conservative. I figure you can't really go wrong with what the manual says.
You seem to sound knowledgeable, is this "replace cylinder" conclusion coming from gobs of experience or you just like to be conservative? I just use what's recommended on my synthetic premix. Used to do 1:40 to be on the safe side but it just spits it out the exhaust and fouls packing very fast, 1:50 seem to be about where it doesn't do much of that and the motor seems to be running better too.
Old 11-07-2009, 02:12 PM   #22
My experience has always been with RS125's which are quite a bit more sensitive to oil mix and jetting. I've got 3 RS125 cylinders sitting on my bench waiting for a replate which illustrate borderline jetting with constant pre-mix ratios. I do tend to be more conservative since I'm a cheap ass. I believe my spooge problem with the CR125 is more from a jetting and riding style issue than mix ratio. The CR is a bone stock '91 still on it's original cylinder (you can still see the cross-hatching) and stock jetting which I know is a bit rich. I never intended this bike to be a racer - just a spare bike for anyone to hop on and go for a trail ride, thus no need for aggressive jetting or pre-mix. My knowledge on dirtbike "replace cylinder - think you meant replate" is admiteddly low since I haven't had a problem with this particular CR125. But if you're talking RS125 then yes - replates are a fact of life when you jet to a knife's edge.
My CR doesn't spit spooge out the exhaust. Just get a little drip when we're done riding. As for your bike running better from 50:1 to 40:1, that change makes the bike run slightly richer which can effect performance depending on the jetting. Everyone has a different preferred ratio. Engine builders like Swedetech recommend a 20:1 for their engines while others push 32:1.
In the end it's your bike and your jetting. I'm just giving suggestions on what has worked for me. If we were all riding '91 CR125's with identical jetting, same gas, riding location, riding style, etc., then 20:1 works great with a little spooge but no cylinder wear. Thus, it's kind of a moot point to argue pre-mix ratios on different bikes. Although please allow me to make one comment - changing pre-mix ratios should never be a substitute for proper jetting. I know my spooge issue is due to a rich slow jet, worn top end, and inexperienced rider. Not trying to step on anyone's toes who have more experience jetting an 01 CR250 because I have none. Just offering jets to micknwop. I'm confident he'll be able to figure out what works best for him.
Old 11-07-2009, 06:39 PM   #23
dakh's Avatar
I Ride: the walk
Thanks for the explanation! I'm 2-stroke illiterate, just lucky my bike's previous owner knew what he was doing since it "just works" so far.
  PNW Riders > PNW Riders > Trail Time
The PNW Riders riding time is 02:37 AM.
